DAC-END R (ES9018) full assembled board
Is it too late to join this gb?
I've got a couple of quick questions. I've got an amanero, and got the acko isolator / reclocker on order (from acko labs) for the amanero...
I don't see why this wouldn't work together? It maybe a bit of an issue trying to fit it in the case (it probably need another standoff).
I've got a JG filter buffer coming too, I guess that would be a suitable output stage for this dac?
I forgot to update my order.Thanks.
1 x audiodesign ( DAC base )
2. 1 x quanghao ( DAC base + DAC chassis + transfomer)
3. 1 x fansipan ( DAC base + DAC chassis + transfomer)
4. 1 x yildiray ( DAC base + I/V opamp+transformers+Chassis+amanero)
5. 1 x danny_66 ( DAC base + I/V opamp + transfomer)
6. 1 x MihajloTM ( DAC base + I/V opamp)
7. 1 x i2k92 ( DAC base + I/V opamp)
8. 1 x axeexa ( DAC base + I/V opamp + tranfomer +DAC chassis)
9. 1 x sipo75 ( DAC base + I/V opamp)
10. 1x Jinkslynx ( DAC base + I/V opamp + OP + tranfomer + chassis)
12. 1 x smoothquark ( DAC base + I/V opamp + OP +/-transformer +/-chassis)
13. 1 x CeeVee ( DAC base)
14.1x Smthgbrrd (DAC base + I/V opamp + OP + transformer )
15. 1 x larslang (DAC base + DAC chassis + transformer)
16. 1 x linuxfan ( DAC base + DAC chassis + transfomer)
17. 1 x randytsuch (DAC base)
18. 1 x claudio52 (DAC base + I/V opamp + DAC chassis + trasformer + Amanero )
19, 20. 2 x danielkol (DAC base)
21. NicMac (DAC base + I/V opamp + DAC chassis + trasformer)
22. gjorgji (DAC base + I/V opamp + transformer + chassis + Amanero)
23. myfavoritething (DAC base+ I/V op +chassis + transformer)
24. MattMax (DAC base+ I/V op + OP +chassis + transformer)
25. bertchai (DAC base + I/V op + chassis)
26. kimgiin (DAC Base)
27. misterrogers (DAC Base)
28. malarkey (DAC Base)
29. TarnishedEars (DAC base + I/V opamp + DAC chassis + Transformers)
30. Boxi80 (DAC base + I/V opamp + OP + transformer)
31. 1x Ridsaudio DAC Base
32. meintan (DAC base + I/Vkit + transformer + chassis)
33. Luizl (DAC base + I/V opamp).
34. inforsit (DAC base + I/V opamp + DAC chassis + trasformer)
35. xtomm (DAC base + I/V opamp + transformer)
36,37,38 3 x kgkim (DAC base)
39. necplusultra (2x tranformers)
40. 1 x halook (DAC base + I/V opamp + Amanero)
41 juju35135 (DAC base + IV opamp + chassis)
1. 1 x audiodesign ( DAC base )
14. 1 x Smthgbrrd (DAC base + I/V opamp + OP + transformer )
42. la1209 (DAC base + I/V opamp + Chassis + Amanero)
Greetings to you!
many of you asked me to register the DAC, I thank you and please do add some more Kit, will stop at number 50.
you need to apply for registration for me! and named to the list!
would like to thank
thanks to Quanghao to re-open the list
42 rliyung/raoul (dac base + chassis)
Domi_78
Hi Quanghao
Just added my name.
43. Domi_78 (DAC base + Chassis)
according post #273
42 rliyung/raoul (dac base+chassis)
43. la1209 (DAC base + I/V opamp + Chassis + Amanero)
44. Domi_78 (DAC base + Chassis)
no only 6v, but you need one more transformer!
thanks
Quanhao,
No problems - happy to get another transformer. However, does the controller support standby and an external relay? I think one of your other controllers did? How about an option (perhaps a daughter board) to implement standby, a trigger output and remote in/out? Would be absolutely fantastic. I presume the chassis would be the really nice silver one that you posted previously rather than the black one in your most recent post?
Hi Quanghao,
Updated "44. Domi_78" -> 44. Domi_78 (DAC base + I/V opamp + Chassis)
Hi la1209 and rliyung,
Due to a copy/paste mistake from rliyung
Corrected "43. la1209 ..." -> "42. la1209 ..."
Corrected "42. rliyung ..." -> "43. rliyung ..."
41. juju35135 (DAC base + IV opamp + chassis)
43. rliyung/raoul (dac base+chassis)
