Hi, could someone please tell me the prices for each part of this group buy?
I saw some posts mentioning 450USD for the DAC base, and now I see payments being done, for 225USD?!
Thanks for some help.
KR
please see post #204
I forgot to update the list. See post # 225.
1. 1 x audiodesign ( DAC base )
2. 1 x quanghao ( DAC base + DAC chassis + transfomer)
3. 1 x fansipan ( DAC base + DAC chassis + transfomer)
4. 1 x yildiray ( DAC base + I/V opamp)
5. 1 x danny_66 ( DAC base + I/V opamp)
6. 1 x MihajloTM ( DAC base + I/V opamp)
7. 1 x i2k92 ( DAC base + I/V opamp)
8. 1 x axeexa ( DAC base + I/V opamp + tranfomer +DAC chassis)
9. 1 x sipo75 ( DAC base + I/V opamp)
10. 1x Jinkslynx ( DAC base + I/V opamp + OP + tranfomer + chassis)
12. 1 x smoothquark ( DAC base + I/V opamp + OP +/-transformer +/-chassis)
13. 1 x CeeVee ( DAC base)
14.1x Smthgbrrd (DAC base + I/V opamp + OP + transformer )
15. 1 x larslang (DAC base + DAC chassis + transformer)
16. 1 x linuxfan ( DAC base + DAC chassis + transfomer)
17. 1 x randytsuch (DAC base)
18. 1 x claudio52 (DAC base + I/V opamp + DAC chassis + trasformer + Amanero )
19, 20. 2 x danielkol (DAC base)
21. NicMac (DAC base)
22. 1 x gjorgji (DAC base + I/V opamp + transformer + chassis)
23. myfavoritething (DAC base+ I/V op + OP +chassis + transformer)
24. MattMax (DAC base+ I/V op + OP +chassis + transformer)
25. bertchai (DAC base + I/V op + chassis)
26. kimgiin (DAC Base)
27. misterrogers (DAC Base)
28. malarkey (DAC Base)
29. TarnishedEars (DAC base + I/V opamp + DAC chassis + Transformers)
30. Boxi80 (DAC base + I/V opamp + OP + transformer)
31. 1x Ridsaudio DAC Base
32. meintan (DAC base + I/V opamp +OP + chassis)
33. Luizl (DAC base + I/V opamp).
34. inforsit (DAC base + I/V opamp + DAC chassis + trasformer)
35. xtomm (DAC base + I/V opamp)
36,37,38 3 x kgkim (DAC base)
Hi Quanghao,
Paid 275$
I added transformer to my order.
Thanks.
5. 1 x danny_66 ( DAC base + I/V opamp + transfomer)
Paid 275$
Thanks.
Hi Hao!
2. The Kit IV stage include:
-2 x Output stage, without 4 x opam 2134
The cost of this modules is: 60$
Can you please clarify point 2 on your post #204 as follow:
2.a The Kit IV stage include:
4 x opam 2134, inserted and tested
The cost of this modules is: $$$
2.b The Kit IV stage include:
4 x opam 627, inserted an tested
2.c The Kit IV stage include:
2 x opam627 and 2 x opan 2134, inserted and tested
Juan
Juan
Paid up. Added transformer to order. Thanks.
32. meintan (DAC base + I/Vkit + transformer + chassis)
test
Hello
Hi Quanghao,
is it too late to join the GB ?
Regards. Raoul.
Hello
Hi Raoul,
- I think it is not too late to join the GB list and may be I'll do it soon.
Amicalement ("friendly" from Paris - France),
Dominique.
I'm pleased to meet you on this forum.Hi Quanghao,
Regards. Raoul.
Dominique.
23. myfavoritething (DAC base+ I/V op +chassis + transformer)
New list with my modified order.
Updated my order and paid.
21. NicMac (DAC base + I/V opamp + DAC chassis + trasformer)
put my name down for transformer only.
let me know if this is possible. thanks.
39. necplusultra (2x tranformers)
amicalement ("friendly" from Quebec - New France)
Some more questions:
1. Volume control via USB
the amanero combo384 can act as a i2c "master". Is there any way to have a two-way communication with the dac-end microcontroller, ie send volume control commands via USB to the combo384 and then on to the microcontroller to raise or lower the volume? If so, it would be fantastic!
2. standby option
Is it possible to add a standby circuit?
3. Remote in/out option
Is it possible to have remote in/out using the microcontroller, ie to control other hifi equipment?
4. 12V trigger option
Is it possible to have a 12V trigger circuit controlled by the microcontroller?
5. Chassis
I am now thinking of housing my mini-itx board in a matching chassis. Quanghao - are you able to get the company making the chassis to make a different front panel with just a switch and ideally a LED indicator ? I am also thinking of building a pair of hypex ncore amps in a matching chassis as well
2. standby option
5. Chassis
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board
