DAC-END R (ES9018) full assembled board
Can I add myself to the list? or I'm too late?
1. 1 x audiodesign ( DAC base )
2. 1 x quanghao ( DAC base + DAC chassis + transfomer)
3. 1 x fansipan ( DAC base + DAC chassis + transfomer)
4. 1 x yildiray ( DAC base + I/V opamp)
5. 1 x danny_66 ( DAC base + I/V opamp)
6. 1 x MihajloTM ( DAC base + I/V opamp)
7. 1 x i2k92 ( DAC base + I/V opamp)
8. 1 x axeexa ( DAC base + I/V opamp + OP + tranfomer)
9. 1 x sipo75 ( DAC base + I/V opamp)
10. 1x Jinkslynx ( DAC base + I/V opamp + OP + tranfomer + chassis)
12. 1 x smoothquark ( DAC base + I/V opamp + OP +/-transformer +/-chassis)
13. 1 x CeeVee ( DAC base)
14.1x Smthgbrrd (DAC base + I/V opamp + OP + transformer )
15. 1 x larslang (DAC base + DAC chassis + transformer)
16. 1 x linuxfan ( DAC base + DAC chassis + transfomer)
17. 1 x randytsuch (DAC base)
18. 1 x claudio52 (DAC base + I/V opamp + OP + DAC chassis + trasformer).
19, 20. 2 x danielkol (DAC base)
21. NicMac (DAC base)
22. 1 x gjorgji (DAC base + I/V opamp + transformer + chassis)
23. myfavoritething (DAC base+ I/V op + OP +chassis + transformer)
24. MattMax (DAC base+ I/V op + OP +chassis + transformer)
25. bertchai (DAC base + I/V op + chassis)
26. kimgiin (DAC Base)
27. misterrogers (DAC Base)
28. malarkey (DAC Base)
29. TarnishedEars (DAC base + I/V opamp + DAC chassis)
30. Boxi80 (DAC base + I/V opamp + OP + transformer)
31. 1x Ridsaudio DAC Base
Fixed the list. Guys, think about it. If you don't copy and append to the whole list, how can this work?
32. meintan (DAC base + I/V opamp +OP + chassis)
I would like to close the list register here.
I prepare the ingredients for the production plan!
Sincerely thank you!
33. inforsit (DAC base + I/V opamp + DAC chassis + trasformer).
If possible.
33. Luizl (DAC base + I/V opamp).
34. inforsit (DAC base + I/V opamp + DAC chassis + trasformer).
Ok?
Ok?
yes! Ok
thanks
35. xtomm (DAC base + I/V opamp)
Rounded ... 🙂
OK?
36. 1 x kgkim (DAC base)
Can i join this project?
We're at 36 from initially minimum 20 participants, so I think it is fair now to have cost reduction due to bigger volume involved. I'm sure everyone will agree 🙂
Quanghao / Andrea, any comments ?
The answer: (slightly) lower cost = (slightly) higher profit😉
The real profit will only come if Quanghao can convince the community that this is significantly better than the similar Buffalo from TPA.
I don't really think in terms of sound quality this will be a lot better than TPA, but is certainly a more complete package ( All P/S, I/V op, chassis, 4 inputs + remote display, etc)
