DAC-END R (ES9018) full assembled board
Transformers
Greetings!
Would you please look at this picture to have the choice transformers for the DAC
quanghao,
What will be the cost including shipment to the EU?
Just the basic stuffed/tested PCB.
The 1200-450=750 price-tag for a op-amp IV, transformer and case does not appeal to me:rolleyes:
Welcome you!
thank you interested in the cost of a complete DAC 32, but you do not compare the price of products, because:
this is the price for the finished product, (it's not like dac kit) you use, so for the cost of a finished product is very expensive many different stages such as:
Labor costs for installation
costs for buildings
cost to run and complete
warranty costs.
hope you understand!
Joined 2009
Changed my interest to just DAC base.
1. 1 x audiodesign ( DAC base )
2. 1 x quanghao ( DAC base + DAC chassis + transfomer)
3. 1 x fansipan ( DAC base + DAC chassis + transfomer)
4. 1 x yildiray ( DAC base + I/V opamp)
5. 1 x danny_66 ( DAC base + I/V opamp)
6. 1 x MihajloTM ( DAC base + I/V opamp)
7. 1 x i2k92 ( DAC base + I/V opamp)
8. 1 x axeexa ( DAC base + I/V opamp + OP + tranfomer)
9. 1 x sipo75 ( DAC base + I/V opamp)
10. 1x Jinkslynx ( DAC base + I/V opamp + OP + tranfomer + chassis)
11. DAHL75 ( DAC base )
12. 1 x smoothquark ( DAC base + I/V opamp + OP +/-transformer +/-chassis)
13. 1 x CeeVee ( DAC base + transfomer)
14.1x Smthgbrrd (DAC base + I/V opamp + OP + transformer )
15. 1 x larslang (DAC base + DAC chassis + transformer)
16. 1 x linuxfan ( DAC base + DAC chassis + transfomer)
17. 1 x randytsuch (DAC base)
18. 1 x claudio52 (DAC base + DAC chassis + trasformer).
19, 20. 2 x danielkol (DAC base)
21. NicMac (DAC base)
22. 1 x gjorgji (DAC base + I/V opamp + transformer + chassis)
23. myfavoritething (DAC base+ I/V op + OP +chassis + transformer)
24. MattMax (DAC base+ I/V op + OP +chassis + transformer)
25. bertchai (DAC base + I/V op + chassis)
26. kimgiin (DAC Base)
27. misterrogers (DAC Base)
28. malarkey (DAC Base)
I wasnt suggesting amanero, warranty, or the IV were included in the $450, in fact that was pretty specifically my point ie. that these items were part of the ~ +$750, not just some transformers and a case. still a little rich IMO, but one must not discount warranty/support as a significant cost for a manufacturer.
what makes you think the real transformer requirements are different to what is supplied?.... that seems an odd question. the IV is an opamp IV, using shunt super regulators, which have a fair bit more dropout voltage than standard IC based regs, the exact requirements will vary based on the supply voltage of opamps you use, the dac regulators will vary somewhat depending on what clock speed and source material bandwidth (44.1khz or 384khz). whether you are using the LCD, whether you are running oversampling etc etc
using the supplied tx as a guide seems a safe bet. I wouldnt go any lower on the dac supply, especially if you want to experiment with running AVCC at higher voltage than 3.3v. the ones for the IV (I run 3.6v, some people run up to 4v, but I dont think thats worth the possible risks/shorter life myself)
I would allow 4-7vdc dropout/headroom on the tx for the IV stage, above the voltage you will give the opamps
Hi Qusp
The Amanero is not included in the price of $450, look below for what is included.
EDIT: And from what I can tell, warranty is only included in the more expensive completed unit, not with the DIY board only offer.
And I do know what the 18V is for (I may be a little slow sometimes, but not that slow ;) ), but I would like to know what the REAL transformer requirements are, instead of the requirements for the transformer that is going to be supplied.
From the first post
This kit include:
- DAC module assembled and tested with all components
ES9018, Crystek 100MHz top performances oscillator (CCHD-950-25-100), five shunt regulator
- DAC controller assembled and tested
16x2 LCD and infrared remote command for volume, input selection and mute
This kit does not include:
- Chassie
- Transformer 2 x 6-0V 2A + 4 x 18V 1A or 2 x 9V 2A + 2 x 18V 1A
- Amanero USB-I2S module to buy directly from Amanero Technologies
- Output stage, only passive I/V
- Input and output connectors
Joined 2006
13. 1 x CeeVee ( DAC base)
HI Quanghao
Add to my pre-order I/V opamp + OP.
18. 1 x claudio52 (DAC base + I/V opamp + OP + DAC chassis + trasformer).
Just let me respond once more to clarify, then I'm happy to let this die.
The completed DAC with Amanero and warranty is approx $1100, exact price not given. That is basically for a working, built DAC with 1 year warranty. It really did not come across to me that you were referring to this package, but that is the only package that includes the Amanero and warranty, and is not part of this GB.
For the transformer, the basis for my question was that transformer was speced as something OR something else, not a typical transformer spec. In a later post, it was explained that the actual requirements are a combination of the two, which is what I expected, I just wanted to confirm this to be true.
Randy
Hi! DAHL75
yes! thanks
Hi, I would like to add my name to the order:
29. TarnishedEars (DAC base + I/V opamp + DAC chassis)
Can I add myself to the list? or I'm too late?
30. Boxi80 (DAC base + I/V opamp + OP + transformer)
