This is the image and try chassis DAC with mica
Sorry to say but I find that to be a rather ugly case. From memory the previous groupbuy case looked a lot better?
Yes, it is bad,
but that demo, it will be real silver!
Do not worry!
Please write your nick to the list DAC32 GR V2.
Thank you.
1. adeveza: DAC module + amanero + output stage + transformer (Complete Set: Item 6)
2. papapew: DAC module + amanero + output stage + transformer
3. smokingdog: DAC module + output stage
4. gde3: DAC module + amanero
5. villanueva: DAC module + amanero + output stage + transformer (item6)
6. MattMax: output stage only
7. CAAD: output stage only
8. blackberry: output stage only
9. Mas Penk: DAC module + amanero + output stage + transformer + chassis
10. rade95: output stage + chassis
11. vmoreau : DAC Module
12. edbk : Complete dac (item 6) (tested before shipping please )
13. sandor: Complete DAC without output stage (option 6 without option
14. Erlend Sæterdal: Output stage only.
15. Colesey : complete dac (item 6) in silver please
Thank you.
Thank you.
16. claudio52: Output stage only
Thank you.
Thank you.
17. Nick F: Complete DAC (item 6)
Thank you.
Thank you.
18. xtomm: output stage only
Thank you.
Hello all here,
i would have also interest in the DAC.
Is it possible to use only the "chip"-section and feed out directly to a Audionote DAC 2 analog tube output stage?
thanks
jogi
thanks
jogi
Hello all here,
thanks
jogi
DO your Audio Note DAC 2 use the PCM63 chips and 6922 SRPP like this ?
http://www.audiofaidate.org/uploaded/tonino60/dac2 audio note.gif
Good Morning Andrea,
so far i can see this is the right thing. The PDC63P and Yamaha receiver, df1700, srpp 6922 are all the same. Only mine is not the signature.
If this would function, i am the next to subscribe.
thanks
jogi
Make sure to include a chassis for me (added to list)
Thanks!
2. papapew: DAC module + amanero + output stage + transformer + chassis
Thanks!
thanks
jogi
You SRPP 6922 output stage is not a differential stage so you should use a transformer like the LL1684 or cheaper type to convert the ES9018 outputs to un-balanced before to connect your output stage.
Hallo,
Thank you for the answer. Do i understand right, that it is because the signal in the AN-DAC is at any state signal to ground. In the ESS output it is separated and cannot be put against Gnd without a decoupling transformer. Then i would have 2 transformers in the signal path. Does this make sense? I first thought that a new digital section with the tube output would be fine. Until now i am very satisfied with the AN-sound and thought this is particular due to the tube stage. But the limitation to 16/48 in 2013 is not the greatest hit.
Would it make more sense to take your analog stage?
thank you
jogi
thank you
jogi
Regarding the output stage, based on my humble understanding, your design is like this:
ES9018 V-out > Discrete V/I > I Amplication > Discrete I/V > MOSFET Class A ouput.
Am I right?
I'm wondering why don't design like this:
ES9018 I-out > I Amplication (like SATRI circuits, which I like very much!) > Discrete I/V > MOSFET Class A ouput.
BTW, what is the purpose of the OPA2134?
I really like the headphone-friendly output design!
Thanks.
Am I right?
Thanks.
Thanks!
19. brgds: DAC + output stage + amanero
Thanks!
20. danny_66: output stage only
Hi quanghao how much for outputstages +frontplate in silver from version 1, and delivery to Denmark, can you send me a pm, for the total price. Thank you.Yes, it is bad,
Do not worry!
Hi!
I'm in the process of selecting a high quality dac and i have some questions.
- Can some one give me a hint of the quality of this one. Is it good value for the money? How does it compare with the buffalo?
- I'm thinking of running the dac voltage out, the a and b dac parallel and in phase via a high pass filter to a single ended output without any transformer. That would just give me 1 v ouput, but I think it would give me enough level in my set up. Is this a good or bad idea?
- How good is the digital volume control compared to an analogue one? I'm thinking of skipping the preamp and running it directly to the amp. Is this a good or bad idea?
Best Regards Christian
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board - version 2
