1. adeveza: DAC module + amanero + output stage + transformer (Complete Set: Item 6)
2. papapew: DAC module + amanero + output stage + transformer + chassis
3. smokingdog: DAC module + output stage
4. gde3: DAC module + amanero + transformer
5. villanueva: DAC module + amanero + output stage + transformer (item6)
6. MattMax: output stage only
7. CAAD: output stage only
8. blackberry: output stage only
9. Mas Penk: DAC module + amanero + output stage + transformer + chassis
10. rade95: output stage + chassis
11. vmoreau : DAC Module
12. edbk : Complete dac (item 6) (tested before shipping please )
13. sandor: Complete DAC without output stage (option 6 without option
14. Erlend Sæterdal: Output stage only.
15. Colesey : complete dac (item 6) in silver please
16. claudio52: Output stage only
17. Nick F: Complete DAC (item 6)
18. xtomm: output stage onl
19. brgds: DAC + output stage + amanero
20. danny_66: output stage only
21. anjogi: amanero + DAC + output stage + transformer
22. CaféNoir: DAC module + amanero + output stage
23. Jazzbear: DAC module + output stage + transformer
24. frankwilker: DAC module + Amanero module
25. NKL: DAC module + Amanero module
26. PeterKD: complete DAC (item 6)
27. rredline: Output stage only
28. schallundrauch: complete DAC (item 6)
13. sandor: Complete DAC without output stage (option 6 without option 2)
29. Stenachio: complete DAC (item 6)
25. NKL: DAC module + Amanero module+output stage+transformer
Hello Quanghao or Andrea,
A couple of questions:
* Will you be offering a LL1684 output stage option?
This post from Quanghao on 11/8 seems to hint at the possibility. I also noticed that build has a firewall-type divider between the r-core transformer and DAC to reduce EMI/RF interference. Did you find the extra shielding to be beneficial?
* Do you think a PIC programmer will be needed with this version?
Thanks,
Sten
Thanks,
Sten
10x330u, you serious? I (personally) don't like the pcb-layout for several thermal reasons. But well, you doing what you do.
Thanks,
Sten
If he does, then I'll change the output stage to LL1684 😉
still waiting his confirmation though...
Here is the layout for the dac, 3d display, when completed it will be the same!
I will race the earliest information about the production of DAC for you!
thank you for your interest!
Hi, Quanghao and Andrea!
It seems that second version of Dac board is quiet different from the first one.
Have you resolved issues with Spdif and shunt oscillation?
Does the second version sound better?
Thanks, Daniil!
Thanks, Daniil!
yes!
thanks
HI!
this PCB LL1684:
http://www.diyaudio.com/forums/quanghao-audio-design/246579-super-v-i-converted-ll1684.html
thanks
Could you try to reduce the trace length between the DAC chip and the decoupling caps? It should increase performance substancially
8. -Removed-
29. Stenachio: Complete DAC without output stage (option 6 without option 2)
8. -Removed-
Hi all,
i am a little confused now. I first asked wether to use an alternative outputstage my own Audionote stage. Then i thought it's better to use the proposed stage.
Now an alternate solution with the transformers is possible.
When i would prefer the transformer stage, what have i to do? Have i to correct recent list here and subscribe the other ?
thanks
jogi
thanks
jogi
8. -Removed-
9. Mas Penk: DAC module + amanero + transformer + chassis
8. -Removed-
new output stage
8. Blackberry output stage only.
12. Removed
Sorry, gotta bail out due to changed plans
12. Removed
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board - version 2
