DAC-END R (ES9018) full assembled board - version 2
1. adeveza: DAC module + amanero + output stage + transformer (Complete Set: Item 6)
2. papapew: DAC module + amanero + output stage + transformer + chassis
3. smokingdog: DAC module + output stage
4. gde3: DAC module + amanero + transformer
5. villanueva: DAC module + amanero + output stage + transformer (item6)
6. MattMax: output stage only
7. CAAD: output stage only
8. blackberry: output stage only
9. Mas Penk: DAC module + amanero + output stage + transformer + chassis
10. rade95: output stage + chassis
11. vmoreau : DAC Module
12. edbk : Complete dac (item 6) (tested before shipping please )
13. sandor: Complete DAC without output stage (option 6 without option
14. Erlend Sæterdal: Output stage only.
15. Colesey : complete dac (item 6) in silver please
16. claudio52: Output stage only
17. Nick F: Complete DAC (item 6)
18. xtomm: output stage onl
19. brgds: DAC + output stage + amanero
20. danny_66: output stage only
21. anjogi: amanero + DAC + output stage + transformer
22. CaféNoir: DAC module + amanero + output stage
23. Jazzbear: DAC module + output stage + transformer
24. frankwilker: DAC module + Amanero module
25. NKL: DAC module + Amanero module
26. PeterKD: complete DAC (item 6)
27. rredline: Output stage only
28. schallundrauch: complete DAC (item 6)
13. sandor: Complete DAC without output stage (option 6 without option 2)
29. Stenachio: complete DAC (item 6)
25. NKL: DAC module + Amanero module+output stage+transformer
Hello Quanghao or Andrea,
A couple of questions:
* Will you be offering a LL1684 output stage option?
This post from Quanghao on 11/8 seems to hint at the possibility. I also noticed that build has a firewall-type divider between the r-core transformer and DAC to reduce EMI/RF interference. Did you find the extra shielding to be beneficial?
* Do you think a PIC programmer will be needed with this version?
Thanks,
Sten
Thanks,
Sten
If he does, then I'll change the output stage to LL1684 😉
still waiting his confirmation though...
Here is the layout for the dac, 3d display, when completed it will be the same!
I will race the earliest information about the production of DAC for you!
thank you for your interest!
8. -Removed-
29. Stenachio: Complete DAC without output stage (option 6 without option 2)
Hi all,
i am a little confused now. I first asked wether to use an alternative outputstage my own Audionote stage. Then i thought it's better to use the proposed stage.
Now an alternate solution with the transformers is possible.
When i would prefer the transformer stage, what have i to do? Have i to correct recent list here and subscribe the other ?
thanks
jogi
8. -Removed-
9. Mas Penk: DAC module + amanero + transformer + chassis
new output stage
8. Blackberry output stage only.
12. Removed
Sorry, gotta bail out due to changed plans
