Yes,I have Ultra bib adjustable voltage.
I mistake dark I/V somewhere so didn't work.
Then I built with Cen I/V at now.
I am so happy that I could upgraded the sound.
The SMD FC CEN IV, as shown, was built to take +/-15V.
So correctly implemented.
And glad to see one actually working.
Patrick
Patrick
Can be this external clock used with ad1862 and with stacked jlsound board. I know that Jlsound has possibility to use external clock.
https://www.audiophonics.fr/en/diy-...dualxo-multi-channel-clock-board-p-17126.html
Can you share what is the sound differenceYes,I have Ultra bib adjustable voltage.
@Tesla Audio - You could email Lyuben this question. He is usually very responsive and helpful.
I use the JLsounds Oscillator board which stacks right on top of the I2SoverUSB card. I can't comment on how it would compare with the Ian Canada stuff.
Hi guys and gals.
I've asked in Ian's thread but to no avail so I ask here about 'snaps' and 'pops' between tracks. Using Ian's Fifo with both XOs populated. Rpi set to no oversampling. I get awful pops and snaps between tracks. I fear for the tweeters.
If I force an oversample to use just one clock it's the same.
Any advice on this?
Any advice on this?
Jimk04, have a look here: https://www.diyaudio.com/community/...fight-the-jitter.192465/page-553#post-7556561.
jou need a monitor pi
Hi, I want to build the PCM63P dac version. I will be feeding it with a WIIM pro that only has coaxial and spdif outputs. Any suggestions on what board for the IS2 convertor? The JLsounds board is usb only from what I can see. So I need a board that accepts coaxial or Spdif and will work with the PCM63P dac. Thanks
This should be able to serve you well.
https://www.audiophonics.fr/en/inte...-module-spdif-i2s-analog-pcm9211-p-16720.html
Thanks. I need to ask Ian if it works on older Fifopi (ultimate).Jimk04, have a look here: https://www.diyaudio.com/community/...fight-the-jitter.192465/page-553#post-7556561.
Thank you zoom777. I cant find that model on ebay so looking for a solution there. Would this work? Do the LED screens cause any kind of interference or noise problems? Is the WM8805 better than the ak4118.
https://www.ebay.ca/itm/166424359358
Can anyone recommend the smd parts for Vunces opamp adapter. I know it's a 0.1uf cap, and 2 47.5kohm resistors. But I don't understand the smd sizing when ordering.
That adapter was whipped up specifically to properly convert the dual OPA1656 opamp for single opamp usage. Since then the single OPA1655 was released, just use a standard SOIC8 to DIP8 adapter and no additional parts are needed.
But, I believe the resistors are 0805 size and the cap is 0603. Just double check that with the supporting documentation in this thread.
this is another option :
https://www.diyaudio.com/community/...s-input-nos-r-2r.354078/page-335#post-7358627
you will only need one dual op amp
- Digital Line Level
- DAC AD1862: Almost THT, I2S input, NOS, R-2R
