Murata gj8 is solid if there is a need for more than 1uf in small space 😁I do never use ceramic class 2 for power decoupling in a dac.
I have never used those Resistors but I have used different series of Dale, RA, welwyn etc. I didn't experience any major differences that made me favour one over another. Perhaps the exotic ones may display discernible difference, I don't know. I spent my money on different usb interface, IV op amp and PSU, which produced different results that I can establish my preference easily.I've seen that some builders of this thread who used Z-foil or S-foil resistor for Riv.
Is there any advantage using Z-foil or S-foil resistor for Riv over a metal film resistor like 71-RN60C2701B?
I use z-foil on pcm63 dac. Haven't tried the restI've seen that some builders of this thread who used Z-foil or S-foil resistor for Riv.
Anyone tried this Walter Jung PS:
https://www.ebay.com/itm/2552562558...3h5Oh4ILxUkq3/XtSWn5n7MVIZPH|tkp:BFBMpv6GxsNi
Yes, you will be proud and self-satisfied!
Alex.
That regulator has nothing to do with Walt Jung, I can only say that it is fraud and unauthorized use of Walt's name.
I played with several resistors and found that the differences are audible. Get a few to play with before spending big $$$.I've seen that some builders of this thread who used Z-foil or S-foil resistor for Riv.
@namghiwook Due to your encouraging posts... Another blue box arrived today...
Sorry I couldn't resist - how do you like the sound of this passive IV versus the active IV ?
Regarding Power Supply. What is better this low noise PSU bellow, based on LT3045 for both 5V and 12V or PSU2
https://www.audiophonics.fr/en/line...-supply-module-2x-12v-5v-33v-25a-p-17612.html
played with them long time ago with amagnetic line : a little better indeed though expensive.Murata gj8 is solid if there is a need for more than 1uf in small space 😁
- Digital Line Level
- DAC AD1862: Almost THT, I2S input, NOS, R-2R
