DAC AD1862: Almost THT, I2S input, NOS, R-2R
Ahaha...
I am guessing but get out the last feedback cap for the second 861in the Vunce's pcb 😉
Told you fellows but discrete the opa 861 as i/v then opa 1656 or ada 4627 as buffers are the great balls of fire...boum. TNT will aprove if he soldered yet 🙂.'
My diy time has been very limited lately, but I will try replacing the second opa861 with another type when I get time.
Suggestions for the buffer opamp position? (Must be in SMD package)
Thanks!
Btw, this thread will keep the opamp industry in business, LOL 😀
Vunce, get out first the few pico feedback cap on the second 861 please :
As well, have you some Allen Bradley 100 to 150R resistors ? 1/8 or 1/4 W ?
The reversed 861 is neutral as buffer and not necessarilly mandated according the following stage. Typically a modern pre/amp doesn't need it but the following resistor after the I/V must be tuned if you use a standalone 861 !
Edit : try CEN/SEN design in smd package : just two transistors ! the J-Fe(s)t is enjoyable but the other non Jfet doesn't need sorting out and is very neutral ! again non mandatory in a normal cable length and a modern amp/pre . But if you use headphoness.... well ! you can also use your smd 861 and a soic 8 single channel 5 V for the buff : new TI's are cool... just guessing 😉 !
I m testing opa810. Listened at low volumes and sounded very good.. need to test more with some known musics..
happy you like it ! 🙂 ! It makes the I/V job very well but less the buffer job : exactly the opposit of the ada 4627-1 !
But the cool thing is they both are single channels oaps so an eventual layout hack is not mandatory which can be a danger -oscillations?- with some fast dual oaps adapted for single use on the pcb !🙁
Supress C10, and raise R8 to 700R. -till to 900R-
Try to hack R10 with a 1/8 W Allen Bradley of the same value. Don't use soldering with silver. You should notice a difference with headphones or good speakers and likes the tonal balance 🙂 !
I used a pair of Traco isolated dc-dc converters to feed my board from my main 24VDC power supply. This worked well but only after I followed the manufacturer's application notes for filtering. Without the filtering I got a fair amount of audio interference.
