After reading about 1000 posts about what part to change I can't judge yet the quality of the device. I have got a small diyhifi.net DAC with PCM 1793, DIR9001 and OPA2134 two years ago and I compared it with some other DACs. The cheap diyhifi-DAC was always the winner.
I would like to test the AK4396-DAC but I'm not sure if it is worth a try without changing 70% of the parts. I had an E-MU 0404 USB with the same AK4396 and the sound was very mediocre.
So how can I compare the sound (modded/unmodded) to some known DACs?
Tolu,
O.K. I'll stick my neck out there. I can't say it is the best DAK in the world cause I haven't heard them all I will say that if you buy and install Dario's upgrade BOM it will take a whole lot of money to get a truly significant improvement over what it offers. I am investigating other approaches to feeding data to the Mini2496 but as a simple proven optimized design, I honestly don't think it can be beat.
I own an M-Box2, a pro Presonus 8 Ch, Lexicon Omiga and the DAC in a top line Denon receiver. I only use the Mini.
ak4396 is a wonderful chip.
it would be almost perfect if it had nos warmth since it already had the smoothness but alas, it wasn't so.
since letting go of my altec transformer coupled mini dac, i've tried discrete output cs4398 and now, back to 1543, this time i2s via waveio board.
cs4398 was very good, midrange bit more juicy than ak4396 and with the discrete module, more dynamic than i could ask for. but it's tonality was wrong. the chip has an apparent brightness that's well known.
1543+waveio is almost perfect. no bass, but mid and high is best i've ever heard. it has no coupling cap. just i/v resistor straight to volume pot than myrefc
i have a 1541 dac on the way so my own humble ultimate comparison will commence.
but as of now, each to their own flavors; there is no clear winner, though 1543 is and always has been my favorite
May I ask why this combination has no bass?
If you have a standard CD or DVD player, they usually have a RCA (normally orange) that outputs spdif. A simple stereo pot between the DAK and the amp works well for volume. In the U.S. I've seen new players for as little as $30 and even less at secondhand stores.
I'm currently running music server, therefore I need USB input. I thought of going with other DAC board that comes with integrated USB but I decided to go with this board due to the wealth of upgrade and modification info.
Thanks Dario for the BOM. It sure looks very promising based on the rave reviews.
About your suggestion above, I may get a used cd player and try the spdif input. But not in the near future though, since I would like to do the BOM modification first.
sorry that was a bit of an overstatement. single 1543, no active
stage is simply not as dynamic as the other methods i listed above.
sorry, don't wanna sound too contrived.
ill rank it by happiness factor. 0-10, unhappy
to nirvana since everyone's preference
is different.
4396 trafo-7
4398 discrete-6 (i like warmth. this one was too neutral)
pcm1704+tube-8
all my past 1543 iterations-8 (once again i only care
for warmth/harmonics)
current setup with waveio 1543-9
is different.
4396 trafo-7
pcm1704+tube-8
Than I suppose that an unmodded AK4396 would be a 5 at your ranking!
I have an DIR9001, TDA1543 with direct out, too. In my ranking it gets an 3-4 because it has a poor resolution and sounded dull.
E-MU 0404 USB: 3.5
Musical Fidelity V-DAC: 4
iBasso D7: 6
TEAC UD-H01: 6
HifiDIY.net (PCM1793, DIR9001, OPA2134 DAC): 7
Northstar Essensio: 8
Linn Akurate: 9
Only my subjective overall voting!
E-MU 0404 USB: 3.5
iBasso D7: 6
TEAC UD-H01: 6
Linn Akurate: 9
i'd say higher than 5
i was actually pleasantly surprised how unoffensive it sounded even with the op-amp in place.
these days i don't care much for detail, soundstage and all that hifi quirks. i suppose since my myrefc amp does them so well that i'm spoiled of those feats. besides, no chip i heard gets the detail right in a natural manner like a turntable can, so might as well not try it if you can't do it- which seems like 1543's school of thought.
Understood, and agree.
Hello,
I would try a DAC from Ebay. You tell me what the best currently playing? Which to buy?
Will be involved from the computer via spdif - DAC -to amp.
Is good idea LM1117 blocking GND/Uout with SMD 402 100nf/50V ?
Just got my kit in the mail today, didn't come with BOM, so looking throught this thread can someone tell me if this is correct one to use for the build?
http://www.diyaudio.com/forums/digi...-kit-cs8416-ak4393-5532-a-10.html#post2582734
well dont expect miracles with the average ebay PCB. many are simply poorly executed, often misunderstood application note circuits all strung together onto a cheap 2 layer PCB.
if it were well made, most 'mods' will measure worse, since many are airwired or using massive replacement parts
but I repeat, I think you are in the wrong thread, with the wrong PCB
I do have to commend Dario though, the BOM at least sticks mostly to existing values, many upgrades consist of quadrupling any smoothing cap on the boardb and adding randomly chosen bypass caps, making every decoupling cap boutique film, using as wide bandwidth opamp as possible etc etc. all the same, wouldnt it be better to actually improve the regulators rather than just using audiophile approved parts?
- Digital Line Level
- DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
