I may bow out at this point...
I'd prefer to keep my da-capo intact as it is in my opinion one of the best dac's ever sold.
Yeah input card and filter would have been fine for me but a whole new mainboard? If thats the plan I may suggest you'd be as well designing a case and selling a whole unit so people don't need a da-capo to use it....
Thanks for helping with all my questions....
Just out of interest when we likely to see a review of your new amp/transport?
Yours
John
Yours
John
dacapo board
I think that, because of the bad caps, there is a lot of dacapo needing a new board.
How many dacapo did pink tringle sell?
100, 500, 1000?
Loris
100, 500, 1000?
Loris
Ordinal
Hello everyone !
Is it possible to have a user guide for the Ordinal DAC with 1307 Da-Capo filter ?
Specially the settings for all the jumpers.
Thanks a lot.
As you see in the attached image, it's not so difficult to change capacitors. I also add a little heatsink on each TDA1547 and a power supply switch.
Hello everyone !
Thanks a lot.
Opa,
I wanted to ask if YOU have one.... 🙂
I have the same ordinal with 1307 ( but faultuy caps) but no manual.
Can you tell me how did you do the power switch?
( a picture )
thanx
Loris
( a picture )
thanx
Loris
another nice job.
too bad I don't have the cover you used, because my ordinal has 2 input:
the standard one and the one for the cardinal with the clocklock cable. (I don't have a cardinal jet)
But maybe I can make one.
loris
loris
1307 filter module
I'll try to translate from an italian review the meaning of the dip switches of the 1307 filter 🙂
( I'm not much into electronics/digitalstuff )
With S/H you chose if you want to sample the audio signal every 3 seconds, to verify the DC content.
If htis option i s not ON, the 1307 sample the DC leven only when swithced on.
If the S/H switch is ON, then the HPF ( high pass filter ) switch must be ON.
The 4th/3rd switch is for chosing the noise shaper.
The DITHER is for applying a dither in AC and DC to the audio signal.
Hope this helps.
Merry Chritmas to everybody.
Loris🙂
Hope this helps.
Loris🙂
Cardinal cd player
hi everyone. My name is Peter C
very interested in Hifi
not much experience.
i have just bought a faulty PINK TRIANGLE CARDINAL INTEGRATED CD PLAYER.
but to my sureprise , there is not a digital filter module fitted,
there are only 2 rows of header
could anyone tell me what is the construction of the cardinal,
does it need to have a module fitted to have audio output??
i could not see any digital filter chip fitted on the PCB. please anyone tell me what I expected and couls anyone can help
thanks in advance
regards
peter C
thanks in advance
regards
peter C
Cordinal or Cardinal
Does this integrated "Cardinal" predate the da Capo?
My son has a "Cordinal" like that integrated and as far as I can recall no filter.
I hear what people are saying..a new year..
Nirvana may lie in the future - new board, new circuits?
Any eta, John W? An email?
On the other hand a bird in the hand...?
New hope for 2007!
Maybe I will get a floor to my listening room.
Best wishes
Alistair p.🙂
New hope for 2007!
Best wishes
Alistair p.🙂
Hi Peter C,
Seems like you have an Ordinal PCB thats fitted within the Cardinal - (can you post a picture of the internals of the unit to confirm).
Anyway - if you see 2 rows of headers (one with 12 Pins and a second with 7 Pins), then yes you have a filter missing.
Try and source a HDCD or 22Bit Filter - these are the best - followed by the 24Bit filter.
Kind regards,
John
Kind regards,
John
Hi Gents
thanks for your replies, i do apprciated for your helps. i will post a pic later .
PS :::does anyone got a filter module for sale??, i live in UK, thnaks in advance.
talk to you later. just another thought , is there any schematic for the cd player , to enable me to ad a HOME-made filter module.
any suggestion!!
regrads
peter😎
any suggestion!!
regrads
peter😎
Filter
Hi
I have one I could lend you.
You could try it and see if it makes a difference.
Alistair p.🙂
Hi
Alistair p.🙂
Pink triangle
Hi Alistar:
thanks for your kind offer. I would like to take up this offer to borrow the filter module from you!! to try out, I will insist to pay for the posatge for the filter,
please email me so that I can give my address to you
thanks again
peter c
peter@hifibug.plus.com
Hi Alistar:
thanks again
peter c
please contact me
Hi Alistair
Could you please contact me so that I can give the addreess to you.
i like to borrow your filter module to try out
my email is
Hi Alistair
my email is
Clock on Cardinal & da Capo
I have just bought a da Capo which has four (4) BNC cards
and no clock interface. I have a clock interface on a PT Ordinal.
My question is:
Can I unplug the BNC interface and simply replace it with the clock from the Ordinal?
They look similar?
Any suggestions?
Alistair P. 😎
PS
I sent the filter..
My question is:
They look similar?
Any suggestions?
Alistair P. 😎
PS
I sent the filter..
🙂 hi Alistair
Recived the filter OK , it works ,but the cd rom judder and start skipping badly!!
i need to repair the transport section!!
any one have any idea how to recalibrate the laser and the electronics??? there are 4 pot to be set, impossible without a calibration method!! pleae help!!
a schematic of the player will help immensely!!
thanks for the help and best regards
peter
peter
- Digital Line Level
- Da-capo issue (John W?)
