D-Noizator: a magic active noise canceller to retrofit & upgrade any 317-based V.Reg.
I must be missing something here. When I calculate the ESR for MY 100µF capacitor (Nichicon UHV1V101MED1TA, 100µF, 35v, tanδ = 0.11@120Hz) and using the formula:
E.S.R. = DF / 2 Pi f C, I get 1.46 Ω. That's a far cry from the coupla-hundert milliohms that everyone here is talkin'. Huh?
Well, I didn‘t calculate this, but only referred to the datasheet value at 100 kHz.
How the cap behaves at 120 Hz, I have no idea. Which frequency range is relevant for the ESR in terms of stability anyway? 120 Hz is mostly relevant for the rectification of AC current.
Well, it's confusing to me. Resistance doesn't normally vary with frequency, but in the case of ESR, apparently it does. At 120Hz, the 100 uF cap is 1.46Ω of ESR and 13.3Ω capacitive impedance; yet at 100KHz, the datasheet says 0.10Ω impedance. But, I do agree, the 100KHz impedance is probably the relevant figure for stability.
It's confusing if you think of a capacitor as resistor, which is mostly linear and it works both with DC and AC.
Resistance on a capacitor is non-linear and only at AC. That's why it varies with frequency.
Joined 2019
LM317 regulator design is supplemented with negative rail LM337 design. It uses same layout as LM317 with minor necessary changes. Compensation capacitor has resistor in series. As kumori determined, LM337 dienoiser is stable with combination of 20 nF + 27 Ω and output capacitor ESR around 300 mΩ.
I decided against both rails on the single pcb, as separate pcbs provide flexibility and I don’t have to design 3rd pcb. :D
  • LM317 gerber.zip
  • LM337 gerber.zip
Reactions: 1 user
@tombo56 Thank you for your contributions to thread. Btw, separate pcb means two independent transformer windings (or transformers) without center tap. Two positive regulators is just enough if we are going two use two separate rails since we can use positive rail as negative one. Negative rail only makes sense in combination with positive rail with center tap transformers in practical aspect.
Joined 2019
Two LM317 dienoiser V1 pcbs free of charge
At Tuesday I will be sending two LM317 denoiser V1 pcbs to one forum member. I have 2 more to go. If anyone needs one or both, just send me PM with shipping address. I will send them free of charge with ordinary untracked letter, so it costs me almost nothing, even for the address at the “end of world”.
Unfortunately, this is currently guaranteed to work only for the addresses inside EU and some destinations around the world, as ordinary postal traffic is cut off among many countries.
Joined 2011
... Negative rail only makes sense in combination with positive rail with center tap transformers in practical aspect.
These PCBs can also be used with a single transformer having a single (non center-tapped) winding, by stuffing some diodes and omitting others, so as to build a pair of half wave rectifiers. This does however require you to use a positive regulator board (with LM317) for the positive supply, and a negative regulator board (with LM337) for the negative supply.
Of course, half wave rectifiers do have about 2X the ripple, since they recharge the filter capacitors half as often. On the other hand, they let you use an AC wall wart as your transformer -- which removes the transformer from the audio equipment entirely, reducing the total volume and size of the chassis. Since the AC mains voltages are no longer routed into the audio gear, it's less dangerous too.
Please be aware: I always referred the de-noiser (not die-noiser). Also, the compensation with lm337 could be less eventually, for example 10nf and 10Ohm. I did not test all iterations, but was happy that it worked at some point. Of course your pcb is prepared for every scenario, so this should be no problem.
It's quite interesting that actual boards are being prepared, carefully designed, both for the Denoiser and the Dienoiser.
It would be interesting if both measurements and listening tests for both were carried on.
I think a participant of this topic was trying these regulators in actual commercial products, and I would be curious to know how both regulators compare to other types, particularly the Superregulator and those using LT3042/45.
Those have been around for some time, and I think are considered to be among the best available. So a comparison might be very useful. Until now we just have simulations, which can be deceiving sometimes, like was recently shown with the oscillations that didn't show on simulations.
Joined 2011
I think I'll wait to see what measured data @carlmart posts, before I decide whether or not to post my own measured data. Maybe his will be spectacularly thorough, precise, and comprehensive. If so there's no need for mine. Not to mention the embarrassment of a looser sigma.
I can't publish or will publish any measured data, because I don't have the necessary instruments.
Joined 2019
Reversed LED polarity error
While adding LED pilot indicator my brain decided, without notifying me, that LED diode should be reversed polarity like Zenner diode. Today, some leftover brain cell kicked in and I spotted mistake.
If anyone ordered the pcbs it’s no big deal. Just mount LED in reverse to markings on the silkscreen. Corrected gerbers in attachment. Sorry for any inconvenience.
  • LM317 gerbers.zip
  • LM337 gerbers.zip
