D AMP is back !!!
Next carrier based damp version. 80-90V per rail max, short circuit protection, nothing special 🙂.
top view:
FPGA-based all-digital amplifier with post-filter feedback
Hi!
I would invite You for the Scientific Student Conference in my school, BUTE, will be held at Friday, 16th October.
We built an FPGA-based all-digital Class-D post-filter fed back digital amplifier. At the conference, we review the theory of the operation, and present the operation of the working amplifier under different conditions. Eventually, you will get a recollection CD-ROM containing the papers of the performances over the sections.
The conference's official website: http://avalon.aut.bme.hu/~lengyel/tdk/TDKProgram2007.htm
Our paper:
http://centaur.sch.bme.hu/~dgyuri/D...u_erosito_direkt_digitalis_szabalyozassal.pdf
Best regards,
Nagy Gyula
Did anyone tried Post filter feedback in bridge mode.......
I am planning to do it by taking the feedback from both outputs and then convert it inot single ended through a differential opamp and then feed it directly to comparator input just like UCD style......
Any suggestions??
I may probably have to face a self oscillating full bridge soon, and common mode errors are evil in differential amplifiers, particularly at high frequencies, so I may probably just ground the control circuit to one end...
Evita,
1.You are talking about turning the negative side rail for low side mosfet into ground reference and i.e. single supply operation....
OR
2. Turning one of the output nodes of H-Bridge into ground reference and make the supply floating.......
Meanwhile i am intrested in 3-Level PWM, but it has got problems with using single differential inductor......or i have to use seperate inductors for each node ....
