Current feedback application of LM1875
I can't see a good reason for the 47 uF cap. Just take the feedback between the .22 Ohm resistor and the load, using any resistor with colours you like. The value is not critical, but it has advantages to use the same value as on the input side. Like you did. This will minimize DC offset and might decrease distortion a bit.
Two smps will work if they are isolated from mains.
Im675 for "virtual ground" seems like waste of energy and op-amps ... You could instead try using two lm1875 in BTL (bridge) mode - not sure how the current drive would have to be done, however...
Something like this?
This is true.
You don't need the 47uF cap.
See this schematic.
But the price to pay is a few mv output offset. In the schematic it is 4mv.
I think the "rectifier" symbols in picture 1 represent smps (that need to be isolated from primary side!!).
And lm675 can provide up to 4 amps, so in principle should work.
As of the encapsulated diode bridge symbols, they do not belong there, worst case square boxes should be drawn with all 4 terminals clearly identified.
A little "SMPS" label by each won´t hurt, at all 🙂
Ok, the LM675 may have enough current capability, in any case it is an active device passing all the load current through and needlessly dissipating power.
Not sure about the cost, but doubt it´s cheaper than getting the proper CT transformer or using two independent SMPS.
Of course, the trivial solution is using the Single Supply version of the LM1875 amplifier 🙄
The very vast majority of SMPS have a so called floating output.
This is in particular true for Meanwell power supplies.
So in that case you can actually use two SMPS in series, and use the "center tap" as the ground.
This is even explained on Meanwell's website.
There are a few practical caveats to this.
You have to be sure that but start up the same time, otherwise the voltages rails won't be symmetrical.
Some IC's really don't like this at all.
This can be prevented with some circuitry.
Also, a lot of those SMPS go into "energy saving mode" aka hiccup-mode for light loads.
Which can be extremely nasty for audio related stuff.
Splitting the rails can also work, although it can be very fiddly.
Keep in mind that you do half the output voltage, although the current stays the same.
So in the end this results in the need of having to buy one higher power SMPS with an higher voltage.
Or two smaller SMPS with lower voltage and less power (same current)
For example 48V @ 2A = 96W
This will get you 48/2 = ±24V
Or split; 2 x 24V @ 2A = 2 x 48W
Reactions: JMFahey
I don't think this will work.
The "inverted" amp will massively influence the current-drive-feedback of the upper amp. Probably BTL current drive is not that easy to do.
I think you're right that the way I posted it will not work well. It's just a driven ground in that ideal case. It's certainly not balanced in the way a voltage out BTL setup is. Even with a symmetrical input signal, the top amp sees the speaker load plus half the sense resistor, while the bottom amp just sees half the sense resistor as load. The way I posted it, the bottom amp sees 0 ohm load (short to ground)
A plain 100-200 ohm resistor in parallel with load will do.
Or turn network into mixed feedback type, allow for a little voltage feedback too, so open load does not turn into full open loop.
Say pure current source gain with normal load is 40X (8 ohm - 0.22 ohm), add a small resistor in series with cap so with no load it shoots up to, say, 400X or tops 800X
Sound will be almost the same, but amp will be safer.
Just for kicks, imagine you nuse NO cap and leave amp unloaded, offset will climb to the roof, output might even hit a rail and stay there.
Not sure amp would be happy.
Reactions: geraldfryjr
