Current feedback application of LM1875
I set it up in Multisim.
It works very well.
The Fourier analysis shows THD = 0.00004%
Beware that distortion is often not included in the device model for an IC, so the results can be overly optimistic. I'd check the model file to see if distortion is modelled before using the results for much more than a "is this broken?" types of investigation.
Tom
Yes I need exactly that as I only use DIY fullrange drivers - one way only - for the complete audio spectrum. These drivers profit from current drive with lower distortion and problems arising from the voice coil can be compensated. Lm1875 is an available chip amp. So I am very interested how to make it work, how to connect it to a power supply, maybe smps if possible as I do not like to buy transformers. Laptop smps are cheap to get. As I am not into electronics I need some tip how to wire all up.
Will any of these arrangements do? Two smps or one smps with lm675 ? Or is this not recommendable at all?
They will NOT work.
To boot, the left bottom one shows NO power ransformer, so is forbidden per forum rules
The fake ground on the right is poorly/wrong drawn and to boot even nif it works it
can only provide a few MA (think a simple preamp), never ever a power amp.
Do the things the right way or stop and do them when you can.
