Complete Novice Needs Help
30 mv and 9 mv, that's pretty good, well within the usable range. Monitor the offset and the heatsink temps for an hour or so. You can hook up a signal source and check the output for AC signal, but don't hook up expensive spkrs to it yet.
Lookin good!
No Heat !
Bill ,
not sure what you mean by centre tap ? here is all the wiring in 4 photos .
I will give you a call later if its ok ... we can cover a lot of ground in a shorter
amount of time ....
I really appreciate the help of everyone with this cherry poppin !
still no reading on the 220 uf !
Rich
Cheers
Farnell are quite good Farnell United Kingdom | world-leading distributor of electronic and maintenance, repair and operations products.
Cricklewood electronics are good on price.
Future are good for cheap IRS parts.
Thanks Nigel ,
I talked to Farnell today . There is no way around their MIN charge as an individual off the street wanting a part or parts mailed to a private address .
I ordered from Digikey ... they are superb - items will be here monday .
Rich
It looks to be correct except for the addition of the trimmer pots. A lot of this is specific to your boards so we can do it here on the forum or through email.
I think the first thing to do is load test your power supplies with a 75 or 100W lightbulb unless you have a big 500 ohm resistor laying around. Rig up a tester, disconnect both amp boards, and hook the bulb up from ground to the rails, one at a time, and measure the voltage with the load attached. Once we know the PSs are capable we can proceed with the amps.
I have tester made up ,but I only have a 60w bulb . Do I need to go to to store and buy
bigger ?
We can keep all this on here if there are no objections . A step by step record of the process may be useful to other virgins like myself .
Rich
Btw, there are no trimmers on my boards .
I didn't see any trimmer pots in your previous pics so that's good, except for Rp2. R19 and Rp2 should add up to around 47k ohms. If you left the Rp2 space blank, the current source will bias up much too high.
I'm going to keep posting as I see things, don't get overwhelmed.
Ok ,
I have no reference as R1, R9 etc . Im not confident following the schematic for this ,but I have just finished measuring everything on one amp board so we could count our way down from the output 10k + ,10k- ....
I have noted the values and what each component measures .
R
