Yes, you can connect the speakers and the source.
You can connect heatsink to Earth ground (isolate the LM1875 chips)
Peter Daniel said:Check the fuse.
Thanks. Some mothers do have them...
Measuring the power supply without the amp boards connected, both measure approx 25VDC across both pos and neg.
Voltage at the wall is approx 216VAC
Now I have connected the amp boards, both amps read approx 29V and 33V across positive and negative respectively.
The chip gets pretty hot pretty quickly. I have changed the pcu heatsinks for pieces of aluminium sheet measuring 4" x 8" x 1/8" which hopefully will dissipate heat better.
Tested amps through two four ohm speakers from a pc speaker system using ipod as a source. Barely audible badly distorted sound from both amps. What to check next?
Thanks as usual
Matt
Are you sure you didn't mixed up resistors on amp PCBs?
The values should be according to schematic here: http://www.diyaudio.com/forums/attachment.php?s=&postid=1508778&stamp=1210693738
Can I really hear the difference between the Premium LM3875 and Classic LM3875 Kit?
I mean, they are the same but use different (pricy) components.
And what about their PCB used with "common" components? Would such a version be a bad expierence?
Only you can answer that: some people hear the difference, some not. When in doubt, I usually recommend to start with standard components and upgrade later, when you feel it might be worth it 😉
What do you mean by 'PCB version with "common" components'?
Well, to be honest I have more faith in your kit. And it saves me time and shopping for the right parts.
Anyway, I ordered your classic kit this afternoon (Wester-Europe time) and hope I can build this beauty soon. :-D
My first chipamp works and sounds fine. Thank you to everybody, it should be impossible without the help of this thread
Renato
Renato
I would say 100VA would be minimum, and I normally use 300VA toroids. As to the voltage, 15-25V AC (dual secondaries or centertapped)
I thought it may be a good idea to post a link here to a place in Poland that produces affordable and very good transformers: http://www.toroidy.pl/index.php?page=shop.browse&category_id=18&option=com_virtuemart&Itemid=2
Ask for a special audio version:
TS300VA PRI:115V SEC:2x22V for AUDIO:
- secondary at the core with 50% higher diameter, single wire (1,8mm)
I used such transformer in my best amp yet: http://www.diyaudio.com/forums/showthread.php?s=&threadid=76609&highlight= althought it was amorphous core, which I hear is not available any longer.
Peter Daniel said:Are you sure you didn't mixed up resistors on amp PCBs?
I have checked this and it was not the problem. I'm a bit stuck now. I'm considering making up the stereo config as in your pictures. If that works, then I will work backwards (or just leave it as it is...) The ony non standard bit of kit is the LED and RLED which I salvaged from a PC. Can this be jumpered or left out to eliminate it?
Matt
Hi Peter
do you think that Toroidy transformers build for audio are better than Plitron of such type
If they were with amorphous core, they would be better, otherwise, they are certainly comparable.
BTW, I also used those tranformers in my Zv9: http://www.diyaudio.com/forums/showthread.php?s=&threadid=85590&highlight=
thx Peter
very good hint
Is that transformer build for audio use - It Is not encapsulated
I am very sensitive to noise - hate mechanical, buzz that some transformers make
have somebody used www.amplimo.com transformers
are they In relation with Plitron
very good hint
Subwoofer on my 3875 amp
I just finished a chipamp.com LM3875. Thanks for the coaching and guidance Peter. I'm running a pair of FR Tangband speakers (3CR-Ti on the PE speaker projects page). I'd like to add a sub to get a little more bass. What is the best way to connect the sub to my amp? Is running the sub in parallel with my speakers, off the speaker jacks, the right way?
Thanks.
Mike
Thanks.
Mike
- More Vendors...
- Audio Sector
- Commercial Gainclone kit- building instructions
