Clock & Re-clocker and interface board for JLSounds I2SoverUSB -> PCM2DSD -> RTZ DAC
I don't use ceramic capacitors for clock bypass at all. That includes for clock module adapter boards made by Iancanada, Twisted Pear, and or others.
However, if you want to try Panasonic SMD film caps on the adapter board, I would suggest to first give the clock and reclocker board some time as is with the MU cap. Then after letting the clock run for a few days just with the MU bypass cap, then maybe try adding the Panasonic film cap to see if it gives any improvement in sound. I would suggest to let the dac run overnight with the added cap so the cap has time to settle in, then see what you think.
