My TPA3255 amp
Case is big))
Later add in this case DSP.
very impressive.
Light version also, with sober H2000 case :
DrMordor TPA3255 looks like possible good candidate to mount vertical with the TPA3255 chip directly making contact to the aluminum finned side of case for better heat thermal dissipation.
IF DrMordor TPA3255 board with PSU built in can be configured for dual mono output with tow of his boards it may work out for a powerful dual TPA3255 HIFI amplifier.
I'd like to see this done if possible.
this is possibleI'd like to see this done if possible.
drMordor that is more like a 110VAC input output 8.4 amp rated 48vdc power supply.
Please confirm if the power supply is a true full bridge/WAVE rectifying power supply design with the option for 110VAC input and 48VDC output with amperage rating design.
I like to see full specifications of build.
Thank you.
Thank you.
This is half bridge resonant PSU
Zener-Diode regulation for DC output?
- Class D
- Class D Amp Photo Gallery
