Class AB "endangered"?
Slightly impractical package, but capable of high dissipation and the tempco has the friendly sign.
https://www.mouser.fr/datasheet/2/692/GS61008T_DS_Rev_200402-1837994.pdf
Have you ever thought of a challenge of building a decent amplifier with ordinary parts like TIP41/42 or 2N5551/2N5401 or MPSA42/A92? I know these audio grade parts were created for a reason, but perhaps one could do reasonably well with common devices. Perhaps some cleverness with compensation can overcome some of the bandwidth limitations.
I have used the generic TIP41/42 and 2N5551/2N5401 and they seem to work fine. It seems that these might be available for awhile.
> its own feedback loop like QSC powerlite
This does not help with 2nd breakdown; the paper is 1998 and in those days they could still buy beefy-junction parts.
What helps with 2nd breakdown is the 4 step class H. VCE (VDS) never gets too high. You can turn most types of amplifier into a 4 step class H if you have enough taps on the power supply.
Output transistors never saturate if you use emitter followers. Seems to be commonplace to switch to common emitter output stages in many “pro” amps to get the cost down, but you certainly don’t have to build them that way. Getting a more or less conventional VAS to not stick to the rails isn’t all that hard either. There is more than one way to make a non-sticking amplifier.
I built a REALLY nice amplifier using TIP41/2 and all generic house-numbered je-ne-sais-quoii TO-92’s for everything else. Back in my college days. Ran off a 25.2V/2A Radio Shack transformer and put out a whopping ten watts per channel.
I think you can get some decent power and performance out of these simple parts. This is an output triple using four parallel TIP41/42 and a 2N5551/2N5401 VAS. The THD is 0.02% at 20 kHz. The output is 38 V peak into a 4 ohm load, or 180 W.
Given that 2N5551/2N5401 is about 2 cents a piece for Chinese versions, and TIP41/42 is about 35 to 50 cents a piece, this is not a bad solution I would think.
Oops, only one of the graphs is in log scale.
Anyway, problem with IRF9610 is, it's a TO220 with a rather large 6.5°C/W RthJC so it's not suited for an output stage unless you use a huge quantity in parallel. But IRFP9240 tempco is pretty civilized too, just a few mV/°C, so I'm optimistic about this one.
