You're welcome.
Given that the Thor crossover needs some work anyway by many accounts, it would seem like an interesting project.
A thought -Small Thor would do nicely too. About a year back, I built (another) pair of Martin King's FE207E MLTL project. The boxes were standard. However, I then added large extensions to the sides. They were not acoustically part of the line, which remained normal because they were only external additions -the internal volume the driver saw did not change. I've attached a quick cross-section of the end result, drawn from above. The black part is the original box. The yellow parts are the separate additions built onto the sides (later filled with expanding foam to kill resonances). No, it's not ideal, but they were only a quick pair of test mules -I'd do a properly curved one for a final version. The effect on the sound was dramatic. Baffle step was pushed right down in frequency, to a point where room-gain was begining to take hold, so it was nicely flattened, in my own room anyway. No BSC circuit required within 30in of the rear wall. The whole subjective presentation altered too -the sound became much wider and deeper in particular. Very interesting effect, and worth looking into. Go for it!
Best regards
Scott
Best regards
Scott
I am working towards building the short thor, getting ready to order the kit parts next month. What would you think about modifiying the cabinet design as indicated in the attached (hopefully) image? I have been reading about baffle step and am beginning to get into the math, but I am new to it all so any guidance is appreciated. I notice in your design you keep it symmetrical front and back. Was this a visual design element of taste, or does it play a role in controlling any sound rebounding from behind? I was thinking that keeping the internal volume as designed, but adding the curved, extended front could look quite nice visually. Sadly I don't yet have the feeling for what impact it would make on the sound.
Thor/Odin
I take it that the consensus is that the Thor is the best Seas kit going these days?
I havent committed to building a Thor or one of it's variants, but I take it that many of you believe it's the best kit under $1000?
What happens to the Thor if you remove the transmission line and make it sealed?
Am I misunderstanding that all the discussion in this thread is concerned with only the Thor's lack of bass performance under 100hz or so? Otherwise its a top notch kit?
imjatse said:I was thinking that keeping the internal volume as designed, but adding the curved, extended front could look quite nice visually. Sadly I don't yet have the feeling for what impact it would make on the sound.
One of the axioms that the Thor family is based on is that it is essential to keep the baffle width the same as the original so that no modification is required to the XO.
dave
Re: Thor/Odin
There are an aweful lot of "kits" for under $1000. Add taste into the equation and i doubt that that question could ever be answered...
dave
Daveis said:I havent committed to building a Thor or one of it's variants, but I take it that many of you believe it's the best kit under $1000?
dave
Amen. Taste is an odd thing -we all like different approaches and value different things, so there's no definitive, sadly.
Given that the Thor's crossover isn't that great anyway according to quite a few who've built it, It'd probably be worth trying the curved, wider front baffle to see what happens. Crossover experts -what do you think? Not my field. What will happen in physical terms is that by having a wider front baffle, you will push the baffle-step to a lower frequency -exactly what that will be depends, of course, on the ultimate width of the baffle itself.
What would be the difference between the original Thor enclosure and a sealed box? Not a lot. The standard Thor enclosure is so heavily stuffed it's basically become a badly designed aperiodic enclosure. Dave and Martin pointed this out quite a long time ago. The frequency response curve for a sealed box of the same volume looks almost identical, though the respective impedences are a little different. A 'proper' aperiodic enclosure could be interesting though, and for almost no extra effort over a sealed type, you'd bet better FL and a flatter impedence curve. I tried simulating one a few pages ago. Not my best as I took a duff approach, so here's a proper one, done in the Ported Box sheet.
3/4in material assumed, & internal dimensions. 45in tall. 7.5in wide. 12.5in deep. Tweeter centre 10.25in down from the internal top. Stuff the enclosure 0.5lbs ft^3 of Dacron or similar from the internal top 25in down. Aperiodic vent centre 4in up from the internal bottom on the rear panel. Couple of options here. You can either use one or two Scan Speak aperiodic vents if you are so inclined, or take the cheaper and more easily tweakable, if not as pretty, option, and cut a hole / slot, and stuff it with reticulated foam or fibreglass, nominally 1.0lbs ft^3.
Best
Scott
Best
Scott
Re: Thor/Odin
Hi Dave,
Before committing to Thor, why don't you consider these two sites:
http://www.humblehomemadehifi.com/
http://www.troelsgravesen.dk/Diy_Loudspeaker_Projects.htm
Unlike the Thor, which contacting the original designer ins probably not an option, these two designers above will stand behind their designs and answer all your questions.
Daveis said:I take it that the consensus is that the Thor is the best Seas kit going these days?
Hi Dave,
This is a killer thread and I seem to come back to it many times. I just can't make up my mind with a project but out of them all, the Thor keeps me coming back. Mostly the Fat Thor.
People have been speaking about that Hobby HiFi mag article about a tweaked xover for the Thor. Is there a scan anywhere on the web?
What I see in it is that the L-C filter seems to be a centered too low.
At least looking at the W18E datasheets say that the big resonance is some 500Hz higher than the filter is tuned to.. Dunno.
Scottmoose said:A thought -Small Thor would do nicely too. About a year back, I built (another) pair of Martin King's FE207E MLTL project. The boxes were standard. However, I then added large extensions to the sides. They were not acoustically part of the line, which remained normal because they were only external additions -the internal volume the driver saw did not change. I've attached a quick cross-section of the end result, drawn from above. The black part is the original box. The yellow parts are the separate additions built onto the sides (later filled with expanding foam to kill resonances). No, it's not ideal, but they were only a quick pair of test mules -I'd do a properly curved one for a final version. The effect on the sound was dramatic. Baffle step was pushed right down in frequency, to a point where room-gain was begining to take hold, so it was nicely flattened, in my own room anyway. No BSC circuit required within 30in of the rear wall. The whole subjective presentation altered too -the sound became much wider and deeper in particular. Very interesting effect, and worth looking into. Go for it!
Best regards
Scott
Scott -- do you have a picture? I was thinking to do the same thing.
btw, after a long discussion with a wood-working friend over a fine bordeaux, we decided that we are now both too old to carry 4*8 sheets of MDF.
right then people i have tried to follow this thread because i was going to have a crack at building the Thor evo 4 or maybe the VOX 200 MHT
after purusing this thread and understanding about 10% of what's been said (i'm a diy novice ) i am left with 2 burning questions
1: is this kit going to give me a nice sounding speaker ?
2: what kind of speaker will I end up with on a price v perfomance level ?
I would have hoped that by building a set of speakers myself I would at the very least end up with a speaker comparable to ones costing 2 to 2 1/2 times as much commercialy. I am mainly into female vocalists and acustic material/piano
all your thoughts would be appreciated
thanks
thanks
Depends what you call 'nice.' The Thor's magnesium drivers are closer to being 'accurate', i.e. very neutral. Some people love this, some don't -you have to decide what sort of a sound suits you best. Hyper accurate; bright; a touch or warmth etc. Only you know which suits you best.
Assuming you like the neutral approach, then the Thor drivers and crossover should be a good option. However, avoid the original cabinet design, which really isn't up to the drill. If you've space, try Fat Thor or Short Thor. If not, Small Thor -Dave has drawn some superb plans for all these cabinets and added them to his posts. You'll get much better performance with these than the original cabinet -you'd have to spend ~£2000+ on a commercial speaker to match or better it. Of the lot, Small Thor is my personal favourite -it's the one I'd build myself anyway, if I was going to buy this kit.
Best
Scott
Best
Scott
Repute and I ran a dedicated 30 amp breaker, 10ga wire and Hubble 30 amp twist lock recepticle and plug.
We then replaced his Parasound pre and Pioneer stable platter CD-R with my Proceed AVP and Sony DVD transport.
We then listened to the the Fat Thors pwred by the Adcom GFA-1,000,000(?) class A to 10 watts, then AB to 300 Watts.
Braided, Silver plated, Teflon insulated speaker wire.
VERY smooth with GREAT detail.. Best sound so far...
This probably directed to scottmoose or dld , but......
In the SHORT THOR drawing it shows a fron-to-back brace with cheese holes - this makes sense OK . But I'm not sure about the 2 side to side/ top to bottom braces.
Can someone elaborate on this ?
I have the drawing dated 15-oct-05 , is this the latest ?
![xeye :xeye: :xeye:](https://files.diyaudio.com/forums/images/smilies/xeye.gif)
andrew01 said:This probably directed to scottmoose or dld , but......
Yes 15-oct-5 is most recent short thor
http://www.diyaudio.com/forums/showthread.php?postid=902735#post902735
Side-to-side braces are holey too.
dave
golden ratio
I still don't understand how to apply the Golden Ration to the side braces of short Thor
The small Thor's goal is 35-50% removal of brace material. Is the Golden Ratio roughly equal to this 35%???
- Rob
- Rob
Re: golden ratio
The golden ratio comes in when you are determining where to put the brace in a fore-aft direction. This is not critical, what is, is to not space them evenly. For example a brace dead centre is in the worst possible place and in some cases might be worse than no brace.
dave
rob3262 said:still don't understand how to apply the Golden Ration to the side braces of short Thor
dave
jackinnj said:what do you do with the swiss cheese holes when you are done ?
You could stack them to build tweeter pods (not for Thor's thou)... Cal found a good use for the insides of his latest "paintbrush" design. Don't know if he has pics yet, but he showed me the plan when i visited a couple weeks ago.
dave
- Clarity on Seas Thor Kit
