Chip Amp Photo Gallery
heatsink enclosure for 3886 RefC
CMoy Headphone Amplifier
Attached is my latest project. A CMoy headphone amplifier. It uses the OPA2132PA opamp.
On the success of this project, I want to try a desktop unit with volume control, bigger input caps, regulated power supply and bypass caps on the chip.
There are a couple more pictures and details at my website.
Overall, the CMoy performs well and it increases listening pleasure with a good set of headphones.
Gio.
Reactions: northa40
Malotron said:
Looks better covered up...
-Mal
Nice looking design, if you took those two aluminum profiles, stacked them end to end, and offset them by 12.25° it would be the profile of the patronis towers in singapore. wow, definately not an architecture student here~ :whazzat:
Can't wait to post my GC amp, ordering the PCBs tommorrow and doing my parts-sourcing this weekend, I finally get to use this pair of 22,000uF caps I've had sitting on my bech for 3 years YAY
-cheers,
Daniel
Rebuilt LM4780
Well after cooking the first set of chips my first Lm4780 is up and running.
This has been a long process(1 year) since I first ordered the chips from National.
This one sounds way more dynamic if i could use that term without getting too airy fairy. I think this has to do with the power supply, as this one was built with a dual mono and it is a parallel design. I used two 300va trannies and four bridge rectifiers.
I think this made all the difference, more power😉
Anyway its not perfect, as there are a few things I'm still sorting(tweaking) as you do..............
