Chip Amp Photo Gallery
Based on Audiosector LM3875. A work done by a friend.
Here is my LM3875 Chip amp project.
I used an old cassette deck, repainted with black and the front panel made from a 1.5mm thick aluminum sheet. I have not very efficient speakers at the moment to test it good, but as for now I can say I'm satisfied by the sound.
I finished my amp a few months ago and I wanted to share my project.
Raspberry Pi 3 w/ IQ Audio DAC running Volumio
7" Touch screen
5V PSU for the screen and Raspberry Pi/DAC
LM3875 Amp
Hello All!
This is my gainclone amplifier based on XY LM 3886 kit.
I built it two years ago, and i am using it since.
The quality of the reproduced sound is absolutely spectacular.🙂🙂🙂
@cok666n- Thank you. The tops are made from 1 mm thick expanded steel sheet, pieces were cut to size, bent and soldered together...3 layers of paint applied after one layer of metal primer.
@levistubby- Your observation is relevant, those IEC plugs were what i had in hand at the time. Security wise, it should not be a problem since i am the only one playing with it.
@NealJ- Yes. That is 5 mm thick brown perspex.
@rabbitz @chermann - Thank you both for your suggestion, i am now reading some technical information about XLR connectors and i see that the 3 pin connector current rating is 15 Amps and the rated voltage is 50V.
Thank you all! Please excuse any errors, English is not my native language.
