Awesome looking amp
That my friend is one awesome looking amp
Looks like the Crowns we used to use in Sound systems
1 K per channel
You must be a proud constructor
1 K per channel
Hi Ray,
you managed to get the middle one in focus.
What did you do different?
I have terrible trouble getting digital pics in focus. Even my SLR gets me spitting pebbles when I see the results on the big screen.
And yet the analogue cameras I use are no problem, even to the extent of selectively focusing on the wanted parts of the view.
This is very much off topic.
Does it deserve a new thread where all you experts can contribute?
Hi Ray,
Lots of light
Andrew,
I had that problem also for a long time. Now i know that most digital camara's have a button with an icon of a flower (tulip). Since i push that button, the results are amazing. That button is for kind of close-up foto's.
Give it a try!
Give it a try!
I agree with wim, Andrew. You should get it in 'macro' mode. It will focus probably on whatever is in the center. A trick is to hold down the shutter button but only about halfway for it to autofocus. Once it locks on then you can move about and anything at the original autofocus distance will be in focus, the rest blurry.
I third it, before I fell on hard times and sold my D80 I was in the habit of using macro whenever the subject was within 4 feet. Their idea of near field is very liberal...
Other than that I liked to leave it on full manual most of the time, so long as you're shooting still life just make sure to take lots of backups on varying settings. Then you can have your pick of the litter.
Mono Blocks with TDA 2050
Here are my TDA 2050 mono blocks.
I was inspired by Thomas Bethe, he allready build this amp.
The transformers are nothing special, but will do the job.
Each mono block uses 2 pcs 22.000 uF for the power supply.
The TDA is running at + / - 25 V.
The TDA Chip sits right at heatsink.
All Caps are WIMA and Cerafine.
I have add a DC protection, because the TDA have no protection.
I keep the signal path short as possible.
The sound quality is very good, even for this low price.
Internal layout and work looks very professional!
My first chip amp
8 LM3886 200W per channel. 600VA 27V and 240,000 uF. I think I overdid it with the caps, but oh well, the more the merrier. Overall, very nice sound, no hum and very very small hiss at the tweeter at about .5 inch.
Wow, That power supply will never run out of juice for sure!.Very nice done.😉
Thanks. I had extra caps laying around so I didnt want want waste them.
I bet you spent a lot of time with your toy there.it looks really a professional job.
I do not see hefty power supply like these to often. Hats off buddy!
Really nice!
If I may ask, did you base your design in the National application notes?
Really nice!
It is similar. Some things i changed are taking out the buffer and my own method to adjust the offset voltages. I also have some output inductors in there.
Folks:
When I made the offer, my 13 year old daughter jumped at the chance to help me build a small integrated amplifier for her bedroom. She did about half the work (including assembling the BrianGT boards and most of the other soldering). We used an extra HiFi2000 chassis and Front Panel Express cut, engraved and colored the front and rear panels. The amp sounds great, she's happy and we had a little bonding time (very important, for reasons all parents of young teenagers will appreciate). All in all, a great father-daughter project.
Scott
Scott
Scott,
Absolutely splendid work. FPE is awesome isn't it? I use them all the time. Please give a huge pat on the back for your daughter. Its nice to see more females get into a hobby that is very male dominated 🙄
Best,
Anand.
Best,
Anand.
Folks:
Scott
I have to say, it is very nice amp and even better when you know you got help from your daughter. my congratulations for you and your daughter!😉
- Chip Amps
- Chip Amp Photo Gallery
