CFH7 Amp
Solidly mounted to heatsink now. Offset is stable to 5mV after warmed up. Bias is stable and set currently at 150mA. Heatsink is not too warm at all. Sounds really nice. Super easy to make and parts are not expensive at all. Great amp. Nice deep bass, smooth mids and clear highs.
Note that bias current is monitored via output and Source pin sticking up from one of the MOSFETs. Be careful not to short the pins with the alligator clip.
Looking good XRK !
Seem like you used some low inductance resistors in the OPS.
I happen to have those - did not know they were low inductance units. I normally use 2w or 3w metal thin film ones here but Marc had it drawn for small stand up rectangular resistors.
Yes X,
MPC71 are low inductance resistors, and they have a frendly parttern and price i find. You can find then under fukushima brand...
Marc
are they low inductance?
What does the datasheet have to say on inductance?
Does the "J" mean 5% tolerance?
I think AndrewT suggested outboard mounting even at the speaker terminals. 1.0 to 1.2uH and 10R 2W in parallel. ...................
The Zobel half of the Thiele Network only operates at frequencies well above Audio range. This demands that the Zobel must have low inductance routes back to where the the HF currents came from. This means the route from output device to Zobel and back to the local decoupling MUST be kept very short and close coupled trace pairs. This means on the PCB.
The inductor half only has to pass audio frequencies. These do not need low inductance in the traces. The inductor has effects on other components and is itself affected by other components and materials. This then requires that the inductor is not located on the PCB. It is better to locate the inductor in the wire pair that feeds the output terminals.
300VA trafo and 39v rails with cap multiplier
I finished my Juma Easy Peasy cap multiplier for stereo and am using it with a 300VA 28VAC trafo which makes 44VDC upstream of the cap multiplier. The cap multiplier loses 5v but ripple as measured with DMM in power supply is now very low, somewhere around less than 1mV. I am running 460mA total bias current (measured with clamp current meter). It feels pretty toasty - almost class A like. I guess it is dissipating about 36w at idle.
Here is the cap multiplier:
579772d1479032560-jumas-easy-peasy-capacitance-multiplier-juma-cap-mult-closeup-02.jpg
So, what does it sound like? Very very nice. Great powerful bass transients, deep reach. Excellent smooth mids and sparkling and clear highs. No issues. The extra voltage really made the amp come alive. I really like it - it is probably one of my top 3 amps now.
Listening to high rez FLAC of Dave Brubeck at 176k through XMOS U8 and BB PCM5102A DAC with external shunt reg PSU. Very very nice.
Here is the amp with cap multiplier and bigger 300VA trafo.
Update on CFH9
This amp as currently configured is really excellent. I measured the DC offset after warming up today and it is 0mV to 1mV. Bias current is still about the same and stable at 465mA. Here is a photo of the amps flat for visibility and then up in vertical config how they would be mounted if inside a cabinet. The cap multiplier also gets warm but not hot so I rotated it for air flow.
I was listening to a track by Gretchen Parlato that I am very familiar with and heard new details today: the breath she takes in between phrases is now audible whereas before it was not as clear. Nice amp. 🙂
