• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
CDROM control KITs VFD version
My kit was waiting for me at work when I returned yesterday. Cheers for the quick delivery.
I've wired it up to an old MITSUMI drive from 2000. It works well but haven't had chance to give it a full listening test yet.
Has anyone used it with a DAC yet, if so can you simply connect it via a diy cable from the digital out or do you have to do anything else.
Cheers
No you can´t. the digital out on your drive is TTL level. You need a converter, which is shown here: http://www.diyaudio.com/forums/showthread.php?postid=1664537#post1664537
My drive sounded rubbish on the analogue out, so I have to use a dac and will build this small converter.
Good luck.
Mischa
markenvy said:
Hi slowgay,
thanks for correction.
I'm trying to put just one transformer, do you think I can use 12 vac for 5v line?
Hi Markenvy
Yes,It can use 12V fo DC5V out.But in high-current output,the differential pressure Control in 6V, otherwise,it will cause LT1084 fever.Output Protection may be happened (such as a sudden drop in voltage is very low, this time, please reduce the input voltage )
Huang
slowgay said:
Hi all
The DC Power DIY kit 's some electronic component are changed
Resistance-----------------200ohm-1/4W------------------1pcs
Capacitance----NIPPON(OR-Panasonic)-4700uF/35V----------1pcs
-----------------------------ELNA-1000uF/35V------------1pcs
-------------samwha(OR-ELNA)-100uF/363V-----------------2pcs
----------------------Philips-CBB-0.1uF/100V------------7pcs
Variable resistor--------3296-10K-----------------------1pcs
Rectifier diode----------FR307-3A-----------------------4pcs
Radiator------------------Black-------------------------1pcs
Fixed screw--------------¦µ3x6mm------------------------1pcs
Insulation gasket----------------------¦µ3--------------1cps
Thermal insulation gasket-------------------------------1pcs
Voltage IC----------------------LT1084------------------1pcs
PCB----------------------Blue--11.16£ø4.2cm-------------1cps
Finished board may add 4USD more.
Huang
Hi Huang,
Can you post the circuit diagram? or show the back side of the board? I want to see if some inductors can be added for some filtering?. Also can you get a hold of some 10uH inductors?
glt said:
Hi Huang,
Hi glt
Here it is.The ELNA-1000uF/35V is out of stock,So I get another instead.
Of course I can get some inductors what you want.
Huang
Gabba said:
What is everyone using for power supplies? - a computer power supply really isn't ideal due to the fan and possible electronic noise affecting circuitry. Anyone made a dedicated one rather than a walwart or anything?
Gabba, for such low power requirements, an AT or ATX power supply may work with fan disconnected. Try this... checking temperatures of the internal heat-sink.
An over-temperature, NTC controlled fan is the best solution for noise and safety, IMMO.
Electronic noise is not a problem (you could also add some filters/regulators)
@slowgay:
kit received in january the 3th.... thanks...
no time yet to test it.
:bawling:
@slowgay:
:bawling:
Hi acid_k2
Thanks for telling me that you received the kit~Holp you like it~
Yeah,I use ATX power supply with fan disconnected before to tesk the CDROM control kit. It's OK too.Just a little big.So I used the 2DC prower kit and one transformer(0-6V-12V/25W) for the CDROM now.It work good too.
Huang
glt said:
Huang,
Here are some ideas to improve your PS kit:
According to the datasheet, http://www.linear.com/pc/downloadDocument.do?navId=H0,C1,C1003,C1040,C1055,P1282,D3741 C7, the adjust bypass capacitor is too small. In page 12 of the datasheet, it uses 25 uF for improved ripple rejection. The datasheet shows 150 uF for C10. I think The original .1 uF capacitor can also be used in parallel for further bypass.
Hi glt
Thanks for your helping~You mean it will improve the kit if I change the C7/c12 to 1uf/150?OK..I will get to try it~^_^.Thanks.
Huang
C7 change from .1 uF to 25 uF, C10 change to higher value (just following the datasheet)
Actually, C9 and C10 can be both changed to say 220uF which is a common value
If you can find all Panasonic FM capacitors, those are pretty good with low ESR and widely used by the cost-conscious DIYer. Another appealing (to DIYers) mod is to use ultra fast/soft recovery diodes.
Hi glt
Thanks for you suggestiong.Sorry for I can't find panasonic FM capacitors.It is very shortage in China.I only can find some ELNA or NICHICON FG/KZ.Is the picture correct now?
Huang
glt said:
ELNA or NICHICON FG/KZ are fine too. I just thought Panasonic FM would be available because they are plentiful here in US.
C7 is 25 uF according to the data sheet
Hi glt
What kind of the 25uF capacitance to instead C7?Just like one of the C8-C11?Or use the non-polarized electrolytic capacitor?Is the picture correct now?Thanks
Huang
