Canned Crossover Design - What Next?
On the Lpad question, the tweeter already has attenuation via the two series resistors (quite a bit actually)... I'm not sure why one comes before and one after the crossover.
If you calculate an lpdad you would want to (at the least) look at incorporating the second resistor into the lpad. you may be able to do away with the first one. I'm not sure what effect (if any) that first resistor will be having on the functioning of the crossover.
Good to hear it is going well 🙂 I've been suprised at how much bass my MTM's have, and they are 5" sealed alignment that starts to roll off around 200Hz! F3 around 80Hz. It is noticable that it is lacking, but they are a lot better than I would have expected!
Tony.
Thanks again Tony.
I might not need the attenuation; I'll tell ya, the tweeters never sounded better. It's nice that the tweeters don't cost a lot, I'm thinking the parts for the xo cost more than the drivers ($50W + $32T).
Q. I guess it doesn't matter the sequence of caps-res.-coil (+ to -) they flipped them on their drawing.
Ive been following this thread with interest, if not sporadically, due to location at present.
Odougbo and I have used the same TBs in forward ported cabinets. (I also found the top range a bit duller than expected - even untreated).
@Odougbo: Did you get that mic going? Very interested in the results you got from your build, which I like very much.
It was the last step I wanted (and still want to) invest in, so this a great resource for me.
However the only mic I have is a Blue Spark.
The resistor (4.7 ohm) after the crossover is to raised the impedance of the tweeter to about 8 ohms. By doing so, the capacitors in the crossover are of a much lower value.
The first resistor (1.8 ohm) is used to attenuate the tweeter.
Mike
Thanks Mike.....I had a guess that the 1.8 could be changed to attenuate the tweeter (have a nice pair of 2.2ohm, maybe I'll try them)
togril, I don't think you'll be hating me if you buy a pair of XT25 tweeters - these are sounding wonderful; great imaging (even with the set-top-tweeters).
Maybe get Madisound to build a XO, I don't think they charge much. I am very tempted to send them a plan. I.e. I have a second pair of W5-1611SAF's
Yes, the first resistor is for tweeter volume adjustment. If your tweeter is too hot, you can try changing it to 2.2 ohms.
Do not change the 4.7 ohms after the xo. Doing so will affect the xo.
The VIFA XT25TG-30-04 are nice tweeters. I have these and the XT25SC90-04. Come to think of it, it was only a month or so ago that I re-tested my 6.5" Silver Flutes (W17RC) with the XT25TG30-04. No problem crossing at 2.5kHz (18dB/oct).
A pm question about the tweeters - going to jump on soap box for a minute:
The Vifa XT25, that's a great tweeter and a great deal ($32). I don't see them working with a 6db slope, but the xo from the d'Appolitito is working beautifully! The depth is so good it's laughable; sound is moving front to back as much as left to right. Bells, etc are floating around the room like a science museum planetarium; hearing details in "strings" that I've never heard before. (they are 1 meter above floor - ear height, sitting)
These are by far the most easy-to-listen pair of speakers I've ever had - can't wait to turn them on again. [I've had many a speaker, store bought, kit, etc.]
btw, I'm only going for 1/2 credit on this hybrid project; the box was a modification from a fellow DIYer, and dido on the d'Appolito xo. If not for the help, these speakers would be sitting on the bench - or might have gifted them.
Thanks to the forum guys!!
Mike
I think my brain was on Holiday Mike 😉 yes the second resistor if changed will definitely affect the crossover slope!! I'm not sure what I was thinking 🙄
I believe it will also be providing attenuation as well. as power must be being dissipated in the resistor. but messing with it would require redoing the rest of the crossover.
Tony.
I did go back and add a terminal for the 1st resistor; thanks for the heads up on that!!
(now it's a 30 second job to switch)
So tried several, even a 4ohm, which I could hear the tweeter, but too low. I settled on a 3.3ohm the highs are fine/better balance.
[the tweeter is on 12" wire/lead, which is handy for prototype work]
Going to build one more pair for sure.
Tony.
Yes, the second resistor does attenuate. The trick is not to overdo it so that you still have some room to attenuate using the first resistor.
I do this all the time because with the higher impedance, it allows me to use smaller capacitors and inductors (read that as lower component cost 😀). Another advantage is power amplifier distortion is lower. Whether it's audible is another matter.
tricky 🙂 It is not something I had considered or come across before!
@KMossman, same could be said to tube amp followers (I'm not one) telling them they should go Class D 😉 Some of us just like to do things the old fashioned way 😀
Tony.
The 4ohm resistor must have been too large and messed with the design (lifeless); however when replaced with the 3.3ohm they came back to life.
I wasn't that unhappy with a 2.2, sure was bright and cheery.
That's the same value I have at the front. I crossed the XT25 at 2,500kHz to the SF W17RC.
My network is just to have an idea of how the SF sounds like with this particular Vifa. If I decide to proceed further, I'll do FR measurements to determine the acoustic crossover and fine-tune from there.
My box is 13 Liters Bass Reflex. Tuning is with 2" PVC pipe. Length = 6.2" for Fb=50Hz.
The Silver Flute W17RC I'm using is the shielded version. I doubt the unshielded one will vary greatly. Should be quite safe to use my T/S.
Thanks Mike - I did order a pair early today.
So the scoop is I'll build a W box - tuning is done with semi built boxes & clamps; tuned @ 50hz. [Odougbo is Jedi Master at this]
We'll see how they compare to the W5-1611SAF, which are getting some rich bass.
Something to ponder - the W5 box is slightly larger (18.5l) with a 3.3" port (if I used a port).
The Silver Flute box will be 5 liters smaller with a port almost double the length (6").
Edit - might be a good idea to build the Silver Flute box leaning to the largest size possible - and shrink the port size.
1st stab at this - plotted in WinISD, my results were similar what was posted in specs. Of course the plan is to enhance the lower end with the 2 flanking rectangle ports.
The TB box is a good reference to work with - the TB's ports are .5 thick x 10" deep x 7" wide (estimated).
