Crossover parts are yellow and on the top layer of the board and the red traces are on the bottom layer and they look now as if the board was transparent.
Hopefully I have done the correct. Will it need grounding if so what connection does it go from many thanks lee
The same rule on parts and copper traces as described above.
I have done it this way well I believe e I have everything seems to work until I put the bass in.it cuts mids out. Do I need to earth them or not many thanks kee
can someone please confirm that the boards look good. As I am ready to put back together many thanks leeWell here we go I believe I have completely done them now. Just need a second opinion many thanks
Hi all again I am going over my old post. I have just noticed when I was trying to use different caps. When there is no caps on the board still plays. I no it’s for the lower speaker. But the mid is also playing is this normal. I would of thought it should on play the lower end not the mid. Hopefully someone can clear this up for me
- Can some one please draw a me a xover
