CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc
So In my case as per above: will changing enable_rate_adapt = Yes imply that any re-sampling will start to happen? (I think no...)
No, but only in this very particular case of the mere 3 devices which support fine-tuning the clock (two on linux, one on MacOS). If you used a different virtual loopback device (e.g. VBA on windows), CDSP would have to use resampling for the two clock alignment (IF further enabled by Async resampler in the config). No rate adjust will by principle always sooner or later result in audible buffer issues for the non-synchronous input and output devices.
  • Thank You
Reactions: TNT
