CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc
So In my case as per above: will changing enable_rate_adapt = Yes imply that any re-sampling will start to happen? (I think no...)
No, but only in this very particular case of the mere 3 devices which support fine-tuning the clock (two on linux, one on MacOS). If you used a different virtual loopback device (e.g. VBA on windows), CDSP would have to use resampling for the two clock alignment (IF further enabled by Async resampler in the config). No rate adjust will by principle always sooner or later result in audible buffer issues for the non-synchronous input and output devices.
  • Thank You
Reactions: TNT
OK, "Alsa Loopback and USB Audio gadget devices on Linux"... I'm so unfamiliar with these items they just passes by. But I see now - thanks!
So when I use a Pi to hook up an USB DAC it will be the Alsa Loopback case, right?
OK, that's the one have tinkered with a bit. I got it to play music 🙂 - both via the Pi built in HP output as well as the DIYINHK MC board.
But I can skip Fs switching and stay 44,1 if it has any advantage... is there?
Hi!
This is a quite long thread... 🙂
I have some issues with CamilaDSP in a PipeWire (on latest ElementaryOS) environment.
I tried to use it this way: Chromium -> PW Sink -> CamillaDSP -> PW SoundCard
This method is described in the CamillaDSP documentation.
Somehow, the output is dead quiet. The Camilla debug log shows, that the signal is arrived, but nothing comes out.
Do anyone use CamillaDSP this way or should I use it by connected to Alsa Loopback?
Hi
since RME Digiface USB is supported in kernal 6.12 i try to use it in camliiaDSP.
I have not tested, if i get sound, but get error messages:
- camillaDSP sample rate change detected, last rate was 60682.462252098274 Hz
And using more than 256 as buffer chunksize will also end in many error messages.
It seems, that the locking on the inputs stops working properly, because, the green LED for the input on the RME starts flashing.
I am not using loopback, i am using the SPDIF Inputs.
If i run Reaper seems to run smoothly.
I am using Ubuntu if this helps.
Thx and greetings
Christian
Reactions: TNT
In Alsamixer i can configure the inputs as ADAT or SPDIF. Ist it maybe, that camillaDSP is using ADAT instead of SPDIF?
On ADAT there are 8 chanels muxed, what could explain the behavior.
If so: is there a chance to change that in the camillaDSP config?
Running Reaper:
Running camillaDSP:
You can coose between lots of Devices... it seems it was the wrong Digi... now it works
Does it work without "plughw:", with just "hw:" instead? The plug enables automatic conversions of sample format, sample rate and channels. You are maybe not be running the device at the sample rate you have selected, it accepts anything and applies whatever conversions needed to make the device happy. With plain "hw" there are no conversions.
Hi Henrik,
switching to "hw" is resulting in this:
2025-05-18 13:58:26.950185 INFO [src/bin.rs:781] CamillaDSP version 3.0.1
2025-05-18 13:58:26.950207 INFO [src/bin.rs:782] Running on linux, x86_64
2025-05-18 13:58:26.951025 WARN [src/audiodevice.rs:536] Needless 1:1 sample rate conversion active. Not needed since enable_rate_adjust=False
2025-05-18 13:58:26.953355 ERROR [src/bin.rs:293] Playback error: ALSA function 'snd_pcm_hw_params_set_channels' failed with error 'Invalid argument (22)'
2025-05-18 13:58:26.966946 ERROR [src/processing.rs:132] Message channel error: receiving on a closed channel
2025-05-18 13:58:26.967008 INFO [src/processing.rs:135] Playback thread has already stopped.
Going back to "plughw" and its playing immidiatly.
Is there any disadvantage to use "plughw" as lomg as input sr is same as output sr?
