Cabinets for Full Range Goodmans Axiom 201
Buongiorno landrupp
I‘ve made the enclosures for my Triaxioms according (+/-) to the original plans published in the web. The Triaxioms came with ARU 172. The Bass response in a room of about 50 m3 is limited. It will be much better in a larger room! I‘ve read, that only enclosures with a tunnel (BR/Helmholtz) or with a damped vent will work good with these drivers. I think that a TL will also work good. Furthermore Ted Jordan has written once, that absorbing completely the rear soundpressure of the drivers is useful.
Cheers
Eric
Hello landrupp
I had the same problem years ago: how to use Goodmans 201.
I started with Open Panels because it was the fastest way to listen to these drivers. The major problem of this configuration is it is visually very cumbersome and has constraints for the placement in the room.
Then I studied the ARU concept and designed a box similar to that proposed by Goodmans with an ARU. I made my own ARU and checked that they worked correctly. To this end, make impedance measurements of the driver in the box. The ARU is a way to lower the impedance peak at resonance. Acoustically the bass sounded muddy.
I made a very simple test blocking the ARU with a piece of Board and made closed enclosures. The result is more than acceptable. The bass extension is down 50 Hz the top end culminates et 14 KHz and what is in between is very pleasant.
Conclusion, make closed boxes of about 130 litres. Stiffen and damp properly the panels. I used cheap cushions from IKEA to damp the acoustic modes, (they are very fluffy and can be easily attached to the panels).
The impedance peak at resonance rockets up to about 100 ohms which most amplifiers accept without problem.
Post scriptum, my experience confirms that cancelling completely the rear soundpressure works.
Would you need more details, (measurements, drawings), give me a mail address and I'll this to you.
Bon courage with this Coronavirus and good listenings, Jacques
Thanks to Jcande and 100ohms for the answers ... why don't you post a picture of your creations? it would be nice to see what you were able to do, maybe even with some photos "in construction" would not be bad.
Even the DIY construction of an ARU would be interesting to know through the images.
Unfortunately, some of you have guessed: for me Covid meant the almost complete end of DIY moments in "hifi", I had to postpone everything to better times, but I am pleased to note that for someone else the DIY-life continues. 😉
Greetings and best wishes from Italy, with great esteem for all of you
Landrupp
Happy New Year and...
...back to Templer's Coral Horn Clone (should we call it the TCHC?)
About the driver's parameters:
Am I wrong, or this post can help you/us: https://www.diyaudio.com/forums/ful...-80-201-measured-parameters-3.html#post878953 (I assume Axiom 201 and 301 have (almost) identical parameters, being that the only difference is one more ring on the magnet).
About the design:
A more general remark, and - please - forgive me if I sound a little bit too amateurish here, but I have a feeling that this horn appllication is forgiving when it comes to dimensional variations (within limits).
My thinking:
• this enclosure was first developed for the Coral Beta 10 and Beta 8 (with two sizes) and it sounds great (I listened to both hooked to very good AN 300B Quest and they keep up with years of upgrades on these amps and the DAC feeding them);
• The internal volume in all the applications is affected by magnet size, presence or absence of tweeter and crossover, protruding magnets and dampening;
• I have this speaker (in a slightly enlarged version) playing the RFT and it sounds great too (photos are in my post above);
• Chris T. first put a Tannoy coaxial (Gold) in an enlarged cabinet, sounded great (my assumption: 12 inch Reds and HPD's would have sounded good as well);
• same Chris put a Goodmans 201 - same enclosure, sounded even better;
• again, he built the same cabinet for Twin Axioms;
• ...but he put THE Goodmans Axiom 80 in same it - sounded best to him (even though this is a 10-inch driver with a different construction).
• the bass extension seems not to be affected by the presence or absence of the "tongue", see towards the end of this article:
"The set made up for the Twin Axioms did not have the protruding tongue as they were destined to stand in one place - mine had to have wheels as I need to move them from time to time. The look much nicer minus the tongue, but as they say "needs must when the devil drives!" There is no obvious difference in how the cabinets couple to the floor with both giving copious bass until the roll off point at 30 Hz. "
In all cases the bass extension was to about 30hz after which it rolls off abruptly.
My conclusion? This is a very forgiving cabinet design. </ducking for flak>
OT:
Anyone that has the 201 or the 301 should try them bare, just for kicks. I did, they sound impressive ;-)
I also built a couple of horns with the help of a carpenter friend. The starting point was Coral-Beta 10 design, but made a little bigger according to Chris Templar and TNT. The material is 38mm HDF with oak veneer and castors underneath for better movability. They weigh just under 100 Kg each and are very stable. First I tried with Tannoy 12 ”and then with Goodman's Axiom 201 which was in my ears better in reproduction than Tannoy. Nowadays I play with Klangfilm KL L-307 which fits in the smaller room I listen to.
Good! what changes did you make to the original Coral / Templer measurements to be able to install the axiom 201 speakers? do you have a dwg, pdf or other file to share?
anyway thanks for your comment, happy 2021
I understand that the great thickness of the panels helped you to insert the 201 simply by making a deeper cabinet with the same internal dimensions of the horn duct ...
Also, I think the magnet squeezed the insulation panel you put in the first chamber of the duct ... or am I wrong?
great work yours, i think mine will be something cheaper, but i share rokiki's opinion: it looks like a cabinet with a very tolerant scheme regarding the possible drivers to mount on it
thanks for the photos, sorry you don't have a project drawing to show us.
great!
Horn is great but there is also sweet sound out of O.B. system. In my mono-rigg I use Klangfilm KL-L405 14" and two Audax 15" bass-drivers for that deeeeep church organ tones. This panel is made out of solid Swedish oak and weighs a ton! Great sound out of Audion 300b and/or 2A3 tubes.
  • siemens-ruf-lsp-t14-klangfilm-kl405_1_6a01756a33dcfe10482fde26a48ad03a (kopia).jpg
wow...
...thank you, 1669EI those are nice open baffles and a nice cabinet for the 201, very thick wood. Great of you to share. Unfortunately, I cannot see any of the facebook links from the previous postings, I get a "content unavailable" message.
Staying within the Axiom 201 topic: the person that sold the drivers to me suggested one possible way to enjoy them without breaking the bank: aim towards building the 12500cu enclosure recommended by Goodmans but build the fronts first and use them as open baffle until you decide whether you want to go to the cabinet or stay OB. Obviously you are past this moment 🙂
If you would be so kind and comment on one thing: you mentioned that "The foam on some of the pictures was never used". You mean you used the goodmans driver without the foam material?
The reason I am asking is that Chris Templer mentioned in an email that dampening the wall behind the driver is a must because of the reflections.
About the foam in the enclosure is that there was never really room for that. After testing the issue of reflections there was little difference in my ears.
Well, I did not try the Axiom 201 in an O.B. set up but that would be interesting. In my mono O.B. the Klangfilm 405 14" sound very good. I do have two tweeters on hand but my ears are 70-years old so the highs are lost anyway.
As Chris wrote, the Tannoy are left behind in favour for the Axiom. For me they sounded very nice in a big room of 40 square meters but now in less than half that size the Klangfilm 307, 10,5" sounds the best. I get plenty of bass thanks to the big lip at the bottom of the horns as the connect better to the floor and increase the lower tones.
