Burning Amp BA-3
I am little puzzling about the psu filtering capacitors! Kendeils are known for their
bright sound. This is not my cup of tea!!! But where in EU find alternatives and which do
you suggest? I look for more fundament but also clear!!! What values are you using?
I guess 100000uF per rail is a good starting point...
Thanks...
Good question! 🙂🙂 The cost for monoblocks is huge!
Has anyone build it this way? Or even whit EI core mains transformers of 800-1000VA?
In two separate cases this huge monsters could have place also bigger capacitors,
I think huge banks of capacitance makes great difference in sound quality at the end...
Something like this....But where to find so beautiful case....Any hints?
Aha...🙂 Čemo nešto srediti....
The secound I didnt know but Mali is well known...Thanks anyway!
Do you know someone is my country who can produce high quality EI core transformers 1000VA?
All I tested where not particular good...
6L6: Yes, this is also an option! Will keep in mind!
🙂 I am in the procces of ordering the mains transformers and
something is bothering me...
What do you thing is better a big 1600VA transformer or two smaller 800VA.
I am aware the dual mono operation is maybe a better solution for separating the two
channels but the bigger core is faster in response....
So what to dooo? At least I know I will order EI core transformers🙂
