Burning Amp 2024!
Ooooohhhhhh!!!
To be honest, to drive a single F4, get a tube preamp.
Both my CJ PV9 and ET3SE are sublime at doing it. You get the crazy *** sound of tubes... on steroids. The F4 is transparent.
So, honestly, if you are gonna drive a single F4, single ended, don't go with cheap, go for the finest preamp you can afford because the F4 will allow the sound to come through. And tubes is where's it at... you need those 20V rms to swing.
The combination makes for the World's finest integrated... if you are OK with just 35 wpc.
Otherwise... if you need more power, if you need the bridged F4, well.... the ARC preamps only swing 10V in balanced mode... I checked with the factory.... so, so, so.... PM me and I'll give you my address and you come and listen to the end result.
Hope y’all are doing great.
Just got the “autographed “ NuTube pre mocked up to the Zenductors (yes, it a brown box rk27 lol). Sounding great.
Only issue was the female end of the Wall wart supply connector not working. The parts fit fine, just no electrical connection.
Now, just need to source parts to display they awesomeness!
Kevin
It was the stock parts from the wall wart that didn’t work out of the box.
I didn’t think to use a bit of tin foil?!
But the trusty multi meter told me where the electrons got held up, and it was easy enough to fix.
My comment about the chinga dera not working was more for others that may have the same issue. I thought it was odd it didn’t work as well.
Kevin
Reactions: tomchr
Are there standards for such things?
Not really. Not for barrel connectors anyway. If you get a wall wart with USB output you can at least count on the connector fitting and providing 5 V at 2 A. But with USB-C that could be different too. I'm pretty sure, but not 100% sure, that USB-C will still provide 5 V unless a higher voltage is negotiated.
So when we buy parts, wall warts, etc.. we know what we get?
If we read the data sheet for the wall wart, then yes.
Tom
Reactions: tonyEE
Well, USB has it own set of issues.
Micro USB is a terrible interface from a physical POV. We just thew away a perfectly fine small Nuforce uDAC-3 because the ground loop for the connector was deformed from too many plug in/out cycles.
And USB-C can be problematic as well. Sometimes if it doesn't work, flipping it over will work.
USB cables are also an issue. Stay away from the "cheap" ones, try to get something that feels sturdy and has a well put together connector backshell.
And, once you've settled on a connector and cable... they will add a new type. Like I said earlier, I got two bins full of all kinds of wall warts but for USB cables I got six or seven drawers... USB-2. USB-3, A, B, mini, micro, C, OTG.... Apple...
The latest USB-3.2 C connectors seem to be capable of sourcing quite a bit of power. And then IT issues you an i9 workstation laptop that needs a Wall Wart From Hell....
Reactions: Kevin.cluse
Hi there,
Yesterday I was looking at the 'original' thread, which I can't find now, and was quite fascinated by the design. However, I have not read all the posts.
Could someone please post the general specifications of the amplifier - I am curious.
PS.
One thing I was surprised about is there are no 'bypass poly-caps' across the output coupling capacitor (?)
tigeranand, I am working with the SB13pfcr25-8 due to the SB12 being out of stock. Needs a bigger box but sounds very goo, I found capacitor value for the SB13 to be around 440uF. I am sure there are other drivers that would work. Audiofy.in appears to have SB drivers in India.
R
Reactions: tigeranand
Is this thread broken? Here's the link for what I'm guessing is the "original post" referred to in the last pertinent submission:
Interesting reading > But I wasn't actually talking about $300 capacitors.
Being a low voltage output amp, I guess my comment barely applies to "The Burning Amp".
BUT, it is an actual fact that at higher voltages & currents an electrolytic with poor to average ESR CAN be improved with a High Quality bypass cap(s).
( regarding high frequency complex waveforms )
Yea, and my thinking on the capacitor subject is: Why do we often automaticly ”belive” that a expensive capacitor is going to sound better?
It might very well be that it is the absolute cheapo garbage capacitor that actually SOUNDS best in a specific application.
If we really wanna know? We simply have to try them, and listen.
Another, besides the point, fact of the matter is that more expensive caps almost always is of higher quality, and will last longer.
