Hi Koldby.(6K8 resistor is from DEM to +5V)
Koldby
I hope you are wrong because I have these from DEM to -15 ??
Rgds,
Hello Ceglar.
I don't know if you still read this thread, but if you do (or somebody else knows) - what is the purpose of the 56uF capacitor over the I/V resistor in your schematic?
Vidar
Hi Vidar
This value is actually 56nF from what i can make sense of. 56uF is totally way too high a value to have any practical purpose in this position.
As many of you are probably aware, this cap limits bandwidth into the output stage by providing a low impedance to ground for the fast transient of the square wave coming out of the DAC.
Hi Koldby.
Rgds,
Hi niamex,
Koldby is indeed incorrect. 2 x 6k8 resistors go to the DEM pins from -15 not +5.
No problem,
Probably not necessary to go with a value lower than 6k8 but i guess it wont hurt, although ive had great results with this value.
56pf is too small a value to be using for this purpose. You should be in the range of 50 to 120nF.
Sure, mistype. Not easy to get the exact value - it is always 6K8 written on it but
Hi Vidar
I wasn't aware. Thank you for that.
Hi Koldby.
Rgds,
Yep my wrong. It is -15V
Hi niamex,
On the distinction-1541 i putted this one : manufacter part number : RG2012P-682-B-T5 (Sussumu low noise resistor RG serie)... You can't go wrong with it... (maybe too small for tweaking EBAY kits !)
Did you check the waveform with a scope? I don't doubt that 10K works too...2 x 10k works for me. I don't think the actual value is particularly important (within some range).
I remember once asking the question how the 6K8 was determined, but unfortunately I got no answer... Your post is a bit of an answer to that question.
Hello Ceglar.
Vidar
Hi Vidar,
56nF//R forms low pass filter.. at higher frequencies the cap represents the lowest impedance path to/from signal common whilst the resistor has a fixed impedance (within reason).
Shane.
The waveform is the same as John's in post #5060. My DEM capacitor is 510 pF, the frequency is 172 kHz. My goal was to achive auto-lock to 4x sample frequency, but it did not occur.Did you check the waveform with a scope? I don't doubt that 10K works too...
- Digital Line Level
- Building the ultimate NOS DAC using TDA1541A
