Negative! The more mass FIXED at the bottom the better the stability.No but the box is doubke MDF so not light.
The shape of the base will be more important than it mass (near negligible) given the mass it is trying to stabilize.
dave
So if you use MDF 18mm diameter 400 or 18mm solid steel plate FIXED to the botom the steel plate win the contest.
This is also very nice for the baffle and top panel between the solid 25mm oak panels.
https://www.behangwereld.nl/a-23846...MVvKiDBx0UWSZqEAQYASABEgKmbfD_BwE#description
Finished! And they sounds beautiful!
