Buffalo DAC (ESS Sabre 9008)
Well put simply, the mod would eliminate the possibility of a fast transient (like a square wave) of causing slewing type distortion. Current output DACs like the Buffalo can slew quite a lot faster than the opamp. this compensates for that.
In short the mod should make the DAC sound a bit better on fast transients. 🙂
Cheers!
Russ
IVY Mod
So, if I'm reading the schematic right, we add 4 capacitors in shunt-to-ground position on the inputs, and in exchange we get to remove 4 resistors that are dead in the signal path for the single ended portion of the circuit? Let me check the parts bin! Of course, I could be reading it wrong....
my soldering iron is still hot....
added cap and jumper the resistor, 2 polystrene caps 4.7nf in parallel = 9.4nf
first impression........much better ^^
will listen further and see if this configuration is preferable
Re: Re: Torroids for Buffalo and IVY
BrianDonegan said:
We carry the 15V trafos because they would work pretty well for all of our stuff, so one size fits all. I will, however, start carrying 9V trafos as of next week. This is primarily to support our new Placid shunt regulated power supply, but will also work well for Buffalo VD.
what voltage / current will the placid be able to supply?
