Dear all, having looked at the current Excel file, I feel the options aren't clear to me, so apologies if I caused some confusion.
Column D is for assembled SMD versions of the board. This is the board assembled with the SMD components, but no assembly of PTH components or Hypex regulators.
Column E is for the Hypex regs. This is separate from PCBs. Put a number here if you want to have the regulators supplied too (not soldered). This is in addition to a number in column D.
Few examples:
Code:--------------------------------------------------------------------------- |Col D | Col E | Meaning | | SMD | Hypex | | |---------------------------------------------------------------------------| | 2 | 0 | Two boards assembled, no Hypex regs | | 2 | 1 | Two boards assembled, 1 set of Hypex regs (for one board) | | 2 | 2 | Two boards assembled, two sets of regs (for both boards) | | 2 | 3 | Two boards assembled, 3 sets of regs (2 for PCBs + 1 spare)| ---------------------------------------------------------------------------
You are not doing single boards (stereo)?
Tfboy,
can you provide a link to the sign on page?
Maybe attached to your signature.
Yes, but that is Bertel's post. It is not clear that the same excel is still current for the Tfboy Group Buy.It is in the first post
Sent from my ONE A2003 using Tapatalk
I think it is just an example. One board should be stereo
Good point Andrew. Than I will need to check my record as well
tfboy has continued to use the GB sheet from the link on the first page and added the columns D and E which are mentioned above. This is still the current and valid excel sheet.
Of course, you can get just one board which is already stereo 🙂You are not doing single boards (stereo)?
I've added the thread and participation list to my sig.
Hypex says: if you buy 100 ea of the pos and neg reg they will be € 10.20 each. That's a discount of more than 65% I think.
Jan
Jan
Dare I ask if anyone has DBT those vs std 7812/7912 in this circuit?
The price is good, but with 3 boards minimum that's an extra €60 🙁
Thanks for asking Jan. I guess I was hoping too much for a better price than buying 10 🙂Hypex says: if you buy 100 ea of the pos and neg reg they will be € 10.20 each. That's a discount of more than 65% I think.
Jan
Edited to add that ends up being around £17+VAT for a pair with absorbing the UPS shipping costs from Holland to UK.
I find this very reasonable pricing for the Hypex regs, also for the assembled board. I would get my own through hole parts, they will just add weight and need bigger box for shipping than just simple SMDs.
Do
Do
I think there may still be some confusion on ordering the regs.
Do we enter 1 for one pair or 2 for one pair.
Many thanks.
Have just read your post properly, must be snow blindness..
Order 1 for 1 pair..
Many thanks.
1 for one pair, or rather one per PCB. That's with me assuming no one would want just one rail regulated à la Hypex and not both.
Having researched the PTH components, I would prefer to duck out of doing it. It would add considerable cost that I cannot necessarily finance, especially with the ELNA caps. Plus, people might have a preference anyway, so it's easier for me to leave those bits out.
I've added the new SMD-assembled BOM as another tab at the end and clarified the Hypex (per pair).
I am interested in a stuffed board.
You should also look at producing Hans Polak's alternative volume control for Bruno's preamp. Description is available at linear audio.
I think we should keep it simple at this stage and look at modifications after the PCB/SMD is sorted.
There is also the mod. to allow 6 inputs.
I tested my preamp with three regulators: 7812/7912, LM317/337 (TO-92 on a PCB of the HxR size), and Hypex HxR.
The differences in the noise measured at the power amp speaker terminals (26db gain) were very small (must search for the data).
Subjectively, I did not hear any differences either.
Regards,
Braca
It depends on how much are you willing to spend. The diy power reg is not cheap too))Dare I ask if anyone has DBT those vs std 7812/7912 in this circuit?
Tfboy, could you please help me to add 2x hypes regs to the spreadsheet
- Group Buys
- Bruno Putzeys Balanced Preamp - Group Buy
