Nixie, dear fellow, you cannot use purely passive components because you need to invert the extracted error before re-introducing it to output stage.
Last time i looked there wasn't a resistor that could do this, old chap.
Clearly, you haven't bothered to read these links.
Bob Cordell wrote:
True. On the other hand, I've noticed that most people are very pleased to hear positive feedback even when accompanied by significant distortion of the truth. 😛No doubt the zero feedback crew will get excited about the possibilities of output stages with EC distortion down at the 0.003% level, though I don't count myself in that number. For example, there are those for whom local feedback in tight loops is OK as long as there is no global feedback. But there are also the more strict sects where even local feedback loops are forbidden. The "feedback-in-disguise" view of EC might not go over too well in this case. And if any of them got wind of the view that EC included POSITIVE feedback, God knows how much fire and brimstone would reign down on them and their ancestors if they used it 🙂.
Quit misinterpreting what I said. Either you enjoy making arguments, or have poor reading comprehension. I never said using purely passive components! Obviously block a in Hawksford's paper remains active. What I was asking, and I'm writing this for the third time!, is why introduce a second active stage R, as he does, on the input sample, rather than attenuate the inverted-by-the-output-stage output sample.mikeks said:Nixie, dear fellow, you cannot use purely passive components because you need to invert the extracted error before re-introducing it to output stage.
The first image is the one from Hawksford's paper, with feedforward loop removed. The second one is what I mean. He has R = A_t as an active amplifier, and a = 1 / A_t, where A_t is the target gain. In my case, there's no R, a passive 1/R (1/A_t) instead, and a = 1. I never said there's no active part, just removing the extra active part A.
Nixie said:........the inverted-by-the-output-stage output sample.
The output stage is non-inverting.
An output stage with gain is usually inverting. And it is output stages with gain that I'm talking about.
Yes. I'm talking about single-active device output stages with gain: common source/emitter/cathode -- all three inverting. Examples: Aleph-X and other Pass-related amplifiers, single-ended triode amps, the electrostatic headphone amp I mentioned elsewhere.
First of all, this is a compound stage.
Second of all, is this the most common gaining output stage configuration, two inverting stages in series? I don't buy that.
And yet again you avoid answering my initial question.
Will you answer my original question? Actually, I'm hoping someone else would comment; I'm tired of mikeks, as he only seems interested in arguing.
Assuming an inverting gain stage, is there any downside to what I proposed instead of the configuration in the paper with a reference amplifier?
Nixie said:Will you answer my original question? Actually, I'm hoping someone else would comment........
Assuming an inverting gain stage, is there any downside to what I proposed .....
Nixie, could you restate your question?, somehow this has become cluttered and I do not have it clear. See whether I can help a bit.
Rodolfo
Offtopic flaming and personal attacks by Zen Mod deleted.
Mikeks and Nixie, please refrain from pointless bickering and defensive attitudes. You both know better than that.
Regards,
Milan
- Bob Cordell Interview: Error Correction
