Big, strange WAW project
the Peerless is only 4.1dB more sensitive than the Pluvia
Typically you want 2-4 dB depending on the room. 6dB requires a really large room and the speaker no where near the walls.
I typically target 3dB.
And keep in mind every dB you raise the on-axis to compensate for baffle step you also increas (in excess) the room response so there is no “perfect".
dave
Reactions: lewisb
Indeed, so for DIYers, best overall IME is do the full 6 dB (or more IME with lossy rooms) if practical from a size/$$ POV and use DSP to frequency shape it in room or if have multiple switchable settings, then shape for various music genres and one for HT.
Hey @lewisb just having a look at it now. Made an frd file from the data provided by the sheets but the response is looking terrible 😂
This is going to take too much of my free time I'm afraid and I don't have that many.... maybe someone who's more into full range drivers can help out?
This is the best i can simulate the Pluvia with the data from markaudio. adding the woofer creates a load of phase issues.
looking at the frequency response.... this is terrible...
made the frd and zma files with SPL Trace inside Vituix.
  • frd pluvia_SPL.txt
    frd pluvia_SPL.txt
  • ohm pluvia_ZR.txt
    ohm pluvia_ZR.txt
