Beyond the J Fringe
:cheers:
What, me worry?
The good news is that between Linear Systems and purchases of some Toshibas the supply situation is improving.
If the lower Idss spec JFETS' operate so well under greater stress, does this mean the V grade JFET's might make a nice power amplifier without having to use one thousand in parallel?
Yes, Through delicate negotiations, both the store and I have scored some
more Toshiba parts, some GR, some BL.
:snail:
I've read this article a number of times last night, and I noticed that in both applications, no changes were made to the circuit for the lower Idss JFET's. It looks like a straight substitution.
Is there a thermal issue driving the lower Idss parts at the same bias as the higher Idss parts? In other words, will a small heat sink be necessary when using the lower Idss parts as a substitution?
Thanks for the measurements Nelson. I came across Borbely's article earlier this week and had mentioned it on another thread, what timing, just as you said this was my introduction. I was in search of a single-ended JFET buffer that could drive the input capacitance of the THF-51S. Good to know lower Idss parts are on the table.
I hope this isn't too off topic, but I wonder if you have any experience with Borbely's JFET spin on the White Cathode Follower. Output impedance of this buffer is quite low, 2.3ohm as measured by Borbely and 4ohm in my simulation, I am planning to breadboard it in a THF-51S design, something like the below. This is my first time designing with SIT, so I apologize if I have overlooked some error.
