Bews NE5534 phono preamp
So the die for such a device is going to be expensive, and when some systems engineer (me) takes this concept to a customer, they're probably going to ask why they just can't put a BF862 in front of a regular op amp?
Thx johnc124, great info.
customers seem to buy (still in production) opa627/637 and Muses01/02 at their high prices. Lots of price room for maneuvering if you consider them.
As with many offerings, it comes down to marketing rather than technical feasibility. I am certain TI and other semis weigh all these points into the product requirements.
We do. To a nauseating amount sometimes, well before UV touches photoresist. I now understand why the team developing the Mustang at Ford met in secret off-site 😉
OPA627/637 still sell at a high price because they're a pretty unique combination of DC precision and fantastic AC performance. With the exception of chopper amplifiers, DC precision will always increase the cost of a part. The DiFet process that the OPA627 is also pretty old, which increases the cost per device. But yes, people do still buy them.
I haven't played with the Muses01/02 yet to know if their performance justifies the price. Muses01 looks awfully similar to OPA2604.
What about adding the cascoded jFET into pins 1 & 8 of ne5534 and disabling the BJT input LTP?
Would that give us a near optimum MM stage?
I think it would be an good solution.
Care to give it a try AndrewT?
Since 2sk146 is obsolete, or very expensive and hard to get from Interfet. When i showed this ckt to the group, Scott Wurcer said that using two BF862 in parallel would be equivalent to a 2sk146. I should have asked at the time as I would like to know how he came to that conclusion?
There is also the example that Bob Cordell has used in the lsk489 app note.
Lots of options if anyone cares to try them out.
The IFN146 has a NF of 1 dB for a 100 ohm source impedance, which is a noise spectral density of 0.653 nV/rtHz, at 1kHz, which is pretty darn impressive! The BF862 is spec'd at 0.8nV/rtHz at 100kHz, so we can expect it to be slightly worse at 1kHz. 2 BF862s in parallel would be 0.8 * 0.707 = 0.567 nV/rtHz, at 100kHz. So they may very well be equivalent at 1kHz.
Mouser has the IFN146 for (only) $16.76, but if we buy a thousand it drops to $10.14! I think you could parallel a lot of BF862s and still come out ahead 😉
INF146
the to-71 package must be a good part of the cost, we should ask Interfet if they can put it in a sot package for us. might be cheaper to ask nxp to put adjacent dies in a sot package for us.
If you are asking $1K+ for phono preamp, like a Bews, it might be justified, to use a inf146. great for advertising, who can say they are using a Interfet part in their front end. The jfet specialists. TI won't afford to put such a good jfet in their devices 🙂
now why did Bews not used a jfet in there design? or did they? cost? performance?
Most of the high end japanese MM phono-amp designs I have looked at all used jfets.
Has Doug Self ever used a jfet in the front end for MM phono-amp?
Fun stuff, talking about obsolete media = LP's
From
MUSES Op Amps are assembled with Advanced Symmetry Die-Bonding (ASD) technology, which achieves higher separation between the right and left channels resulting in well-balanced symmetry.
Muses are duals and are expensive because of special technology that provides good separation. Considering that only the best and the most expensive turntable pick-ups have 30dB separation between channels, I doubt that such level of separation in opamp is necessary. Even industrial quality dual opams have separation over 80dBs. For RIAA circuit such separation is simply more than adequate. Opamp is not limiting factor for separation in RIAA circuit.
From
Hmm, yet Muses8920 seems to have almost identical channel separation, at 1/4th the price? As well as having lower noise? I'm not discounting the possibility that they use an expensive manufacturing technique, what I still fail to see is how the performance achieved justifies the price of $46/ea on Mouser? 🙄
Most modern op amps achieve this level of channel separation through proper IC layout engineering. For example OPA1688 is a monolithic CMOS amplifier with 140dB of channel separation at 10kHz (4dB better than a Muses01) and is around $2/ea.
But in reality, as you say, these numbers are useless. In a real system the channel separation is totally swamped by the effects of op amp PSRR (wish I could find a Muses01 PSRR curve) and the impedance of the ground plane. And furthermore, all that channel separation is ruined once sound comes out of my stereo speakers. Sound from the right speaker mixes with the left and vice versa in total chaos! 😉
OPA1622 has Advanced Symmetry Pinout (tm) as well
In this case we did it to minimize thermal distortion effects due to the high output current capability of the OPA1622. If the output stage of one amplifier produced a thermal gradient across the input stage of the other amplifier, you could have cross-channel thermal distortion effects. The OPA1622 die is laid out along a single thermal line of symmetry to prevent this.
Using a jfet as the first stage of the NE5534 is old technology. See the link page 28.
Okay, thanks great paper. but the ckt is recommend in this paper.
If you read p 28-29 and look at fig 22 the author proposes the same ckt to bypass the ne5534 input and use lsk389 instead.
However, here is another circuit version which I can strongly recommend.
Today's best audio amplifiers in terms of both noise and distortion are probably
the LME series (developed by National Semiconductor, now owed by Texas
Instruments). In particular, the LME49990 offers 0.9 nV input voltage noise, rtHz
1.8 pA input current noise, along with a distortion figure with an impressive
amount of zeros before the first significant digit. If your favourite cartridge has high
electrical impedance, the current noise component may still be too high for you, so the
already mentioned OPA827 with a jFET input, and consequently negligible current
noise, will be the natural choice.
There is a way around this dilemma if we consider using discrete jFETs. The
LSK170 is a single and LSK389 a dual low noise jFET, with the input voltage noise of
0.9 nV at 1 kHz, and 2.5 nV at 10 Hz, and the input current noise down
into the fA level (devices are produced by Linear Integrated Systems). If these
are used to form the input differential amplifier stage, their output can be connected to
an ordinary NE5534 instead of its own input stage, which is disabled by connecting the
inputs to the negative supply rail. The input to the second stage is available at pins 1
and 8 of the NE5534, which are usually used for offset correction. So we have a
composite amplifier with extremely low input noise, low distortion, and good load
drive capability, and the circuit is easy to build. The connection, shown in , Fig.22
appeared in a data sheet catalogue of Siliconix FETs in the late 1970s, employing the
2N5911 pair of FETs at the time.
Noise spec is important in RIAA circuit. Most MM cartridges have impedance around 1000 Ohms. That's exactly source impedance that provides the lowest noise for NE5532. NE5532 is still one of the best choices for RIAA circuit, plus it is readily available at low price and in DIY friendly package. For DIY project look no further.
gbp? Sorry, new to this. OK, so it seems fine as Mac had it, which makes sense as they are typically cautious about their designs... often to a fault. Thank you kindly for looking at that and verifying! Also thanks for the very nice link... it looks quite useful. This maybe overly specific, but do you happen to have a link or info on setting an offset null?
yup that is the ckt, same as I have in the application manual too. now that I think about it some more i think this the way I made it back in college. It worked fine, as far as i could tell.
... since 5532 is internally compensated for unity gain, at least 34dB of feedback exists for a 10MHz gbp.
...the ckt is fine and my concerns are alleviated.
...if you use a 5534 you could eliminate the feedback ecap and use the offset null pot, but that adds cost and you have to do the adjustments.
Looks like a gem! Thank you for sharing. If you were using an SUT between the RIAA stage and a low-output MC, would the OPA1642 still be your choice for a single op-amp phono pre? I imagine that a typical SUT has between 50 and a couple hundred mH inductance, albeit that might be less critical when loading an SUT vs. a cartridge.
Thought I'd through a more modern Burr-Brown option into the ring. The OPA1642 makes an excellent single stage MM phono pre-amp. For MM cartridges there are two major noise considerations that most people ignore and simply look at broadband noise spectral density. First, input current noise of the op amp is really important because MM cartridges are highly inductive. For example, the Shure M97xe has an inductance of 650mH. At high frequencies, the input current noise multiplied by the cartridge impedance may be much larger than the input voltage noise. Second, low frequency noise (both voltage and current) is critical because the RIAA gain curve is highest at low frequencies. For these reasons, the best choices for MM phono preamps are op amps with front ends that use, JFETs, super-beta BJTs, or BJTs without input bias current cancellation. The OPA1642 is a JFET part (consider it an updated OPA2134).
