One question to people who have dismantled the 557s/567s monitors: are there any jumpers on the LCD controller board which could be used for disabling the dithering (= mapping from the 16M palette to the 262K color palette by displaying alternating colors from 262K color map on screen causing also visual artefacts in moving images)?
In France, the FP567s and 557s have the same panel :
Au Optronics M150XN05, 262K, 16 ms, dithering.
mhelin :
I've read this test :
http://www4.tomshardware.com/display/20030626/lcd-05.html
"But if the color is not in the 262,000 table, the panel will display the two closest shades alternately. Because the display is very fast, your eye will only detect one shade, the right one. But for you to see an image, the monitor has to draw two of them"
They don't talk about "...visual artefacts in moving images..."
Can you confirm 'ghosting and artefacts' with theses 'Au Optronics 16 ms panels' ?
mhelin :
ghosting
lol there is no ghosting or visual artifacts on the Au Optronics 16 ms panels, but mhelin is obsessed w/ getting his true 16 mil colors becuase I guess his eyes can see things ours can't. good luck, let me know if u find 1 w/ a response time this fast and this cheap.
E
E
Even a blind can see the flickering of the screen when the whole screen is filled with a dithering color... Unfortunately. But you can use 16-bit colors in Windows and calibrate the monitor so that dithering is virtually non-existent.
Webster's say's: - dith-er: to be nervously exited or confused...Welp! I'm dithered about dithering
Is there any humanly perceptable flickering or any other negative from dithering...just need to know if I should be concerned about this spec. when shopping for an LCD. Pardon my newbie inexperience, but I'm sensitive to such contoversies
Is there an easy way to take apart the plastic case on the FP557s? I took out all of the screws but there seems to be some clips at the bottom holding the case together. Im tring to do this without damaging the shell.
The dithering doesn't really cause flickering, at least i don't see any. What it does do is reduce the colordepth (<<16M colors) and response time.
The colordepth is noticable esp. if you need to adjust brightness because your picture is too dark; the remaining colors after the brighness offset are not enough to render a true color pic.
The response time causes a cloudy smearing of the pic at fast moving camera positions.
If you have a choice, go for a real true color panel!
The specs are ALL LIES, no manufacturer will give true panel specs! Try to get the panel type before you buy a monitor and get the specs from the panel manufacturer!
I took the fp557s entirely apart and set it up on my ohp. Plug it in and nothing. It must be broken! I wipe the tears dripping from my forehead and put it back together, Presto its working again. While on the ohp, I connected the lcd, controller card, powersupply, power cord, vga cable, and front panel buttons. Evidence, did you need to ground anything.
ground
On the second page of this thread is a pretty good picture of how I had it setup. The only ground I made was the green wire in the lower right corner of the pic, and i dont even think it was necessary. Most of the connections can be seen in the pic. Let me know if you need any more help. Good luck.
E
E
The green wire is the only thing I did not connect. Do you just have it connected to a peice of metal? Ill give it another go in a couple days. hopefully Ill have my digicam by then.
Look at my little web page :
http://cfeuillet.free.fr/KolimaVP.html
You will find :
- How to dismantle the FP567s
- First quick Test. ( With an OLD 250W OHP)
- The ballast and the bulb that I bought.
I am building my Box...
Sorry, web page in french
You will find :
hey Kolima nice job i too am using 250w HQI 🙂
ok any ways..what are the specs of your LCD (i've heard many conflicting specs)
i plan to get that LCD too since its cheaper than the 1560M
and how much of the screen is cut off?
First, I DID NOT USE BULB HQI YET.
Theses first results are with the 24v/250W bulb of the OHP.
(The bulb is 7000-8500 lumens, 3400°K. Not really sure about the specifications)
Inside the OHP, there's a reflector and a condenser :
For the 567s :
- If paid 325 € (3 years guarantee). I did not find the 567 (without speakers) in France.
- The LCD is an AU Optronics M150XN05 v1.0 : http://www.auo.com/e_products_monitor_m150xn05.shtml
- The size is 317x243
- The active area is 304x230 mm
- So, there is :
5 mm on the left without pixels. 8 mm on the right. 5 mm in top. 8 mm in bottom.
- Thickness = 2mm
One problem : there's a film stuck on the front of the glass. (polarizing film ???)
Tomorrow, I builds the supports for Fresnel and the LCD and I test with the HQI
For the 567s :
- So, there is :
- Thickness = 2mm
The results will be on my page. It's simpler for me.
It's difficult for me to speech in English and I am still under moderation.
I must wait several hours to see my posts and the answers.
Because of that, many Europeans do not post on this forum. It is a pity. 🙁
Negative Design said:hey Kolima nice job i too am using 250w HQI 🙂
Hey,
The NEC 1545V is actually alot cheaper than the Benq. I just bought one offf ebay a couple days ago for only $215. But just yesterday, a couple of them was sold for less than $200.
i dont want the 1545 i want a higher CR:1
the benq is/was 189$ refurb but they dotn sell them any mor eon that site 🙁 so now im looking for another LCD to buy...
