Balanced F5 question
> CCCCC-R-CCCCC-R-CCCCC-R-CCCCCCCCCC
That's not enough C's for me !!
Patrick
PS
What you see is only 1/3 of the caps for one of my AXJ monoblocks.
Another 1/3 is hidden below, and yet another 1/3 is mounted close to the power modules.
All hand matched to 1% of course. We bought 1000 in total (220uF 50V Panasonic FC).
PCBs are double sided 205um thick (normal PCBs are 35um).
And this was 2004.
> It's a fairly even race so far. I bet Patrick is pulling his hair out.
I already have solutions for both.
Probably easier life for CRC as Reg means extra heat sink.
But there is a solution that is good enough for me.
We now even have a design equally good looking for MF35-100, for the single ended F5 guys.
Patrick
Push button means an extra PCB with some control logic, at least a toggle.
If you want to do speaker protection, soft start, ...... (and I do), then you need an auxiliary control board anyhow.
But if you want bare minimum, then probably no switch is better. Hence the option.
Patrick
C-R-C
thanh1973
alazira
Russellc
Bksabath
smyslow
C-Reg-C
ashaw
qusp
pchw
400
TheShaman
AR2
Parallel survey :
Yes or no Stainless Steel Push Button (1x 10mm, not toggle switch) on the front panel :
Yes Push button
ashaw
xxx
xxx
No Push button
xxx
xxx
xxx
C-R-C
thanh1973
alazira
Russellc
Bksabath
smyslow
C-Reg-C
ashaw
qusp
pchw
400
TheShaman
AR2
Parallel survey :
Yes Push button
ashaw
TheShaman
xxx
No Push button
xxx
xxx
xxx
SorrY for mine I have
Apem 16 mm stainles stell security vandall proof like RS components 278 1149.
This will either be taken as a Joke or put the delay the design 1 or 2 weeks.
Speaker protection sound good just think at what she will say if you blow your speakers.
I am working on it but ...
DC Detection is a low filter say 2Hz or around there, and the rest is litle 8legged critters so any pointers to other alternatives are most welcome.
Al
C-R-C
thanh1973
alazira
Russellc
Bksabath
smyslow
C-Reg-C
ashaw
qusp
pchw
400
TheShaman
AR2
Parallel survey :
Yes Push button
ashaw
TheShaman
Horio
No Push button
xxx
xxx
xxx
Parallel survey :
Yes Push button
ashaw
TheShaman
Horio
qusp
No Push button
xxx
xxx
xxx
wow thats a nice statement and I look forward to the pics, because the APEM push buttons are the sexiest i've seen! I have them on both my current builds. I got this really sweet one that is just a flat brushed alloy disc and it doesnt push, instead uses piezo-electric energy from the finger, stays still no mechanism.
