Babelfish M25, SissySIT - general building tips and tricks
I am very interested to hear your findings about the differences of hi-nickel vs. lo-nickel Cinemags, because I only ever have heard the high-nickel one 🙂
Best regards, Claas
Nickel core transformers have significantly lower distortion at low signal levels, but tend to saturate earlier but it depends on how they are implemented within the circuit. . 80% Nickel should be more immune to hum (dead silent) as the nickel affords higher permeability (conductance Mu) and increases primary inductance.The better beast of both of them is Metglas® core transformer or nanocrystalline cores are superior in transparency and reproducing detail.
I have a number of these big PP caps from ISKRA (surplus material but in perfect condition). My intention was to try to adopt them on the Sissy (the problem is size, they measure 14 x 8.5 cm). The intention was to use them as decoupling Rail to Rail, so it would take two as it is a dual mono. So I should intercept the +24 and -24 cables near the amplification board. Does that sound like a good idea?
All in a days smoke....yes RN55. I forgot to order one part 7805 regulator, but I needed parts for papas 7 so it’s all on order now. Zen Mod what does C3 do? Notes say R13 C3 only for edcor.
no need for that..... I can't see any benefits
edit: just complications ..... switching reg asking for more uF for stability , while with regular 7805 you're good with 100nF in front and at back , in proximity and with this level of current
