BA-3 As Preamp
I adjusted the pots from one end to the other. I found the 2nd to be higher than the 3rd at one end, and the opposite on the other end. I did a sweep a couple times and found the results similar. I'm using an app on my phone to make the measurements. While I'm sure it's not the best way to do so, it still clearly showed changed in the harmonics.
I'll recreate the test tonight and eliminate as many variables as I can. I'll use the same speaker, in the same location, same cable to same channel on my amp, ect.
So I tried it again last night with a different microphone and had similar results. I tested one side of the amp with one speaker. Basically, it was the same. Not much of a surprise here considering my crude testing techniques.
This morning I tried again using the method in the video in the link above. I ran the preamp straight into my computer and used the same program to test it. I was much more clearly able to see the harmonics. Adjustmenting this way made it easier to see what I was adjusting. The difference from where I had it to where I ended up wasn't drastic, but now I feel I am in a better place and I know the channels are similar.
Thank you all again for the suggestions and help.
bigger common heatsink or not???
hi all,
as for routine i keep adjusting my ba3fe preamp every few month
and always go crazy about that jumpy behaviour of Iq & DCout.
its like trying to mount a pin upright on a knifedge.
so would it be an improvment to mount p & n output-transistors on one common heatsink in order to add some sloth to its behaviour??
has anybody done that before?
advice appreciated!
Having a common heatsink would help, yes.
However, don't worry about it, the circuit was designed knowing that there would be a bit of offset, and that it changes as it warms up -- hence why there's a big capacitor on the output.
thakx for the response! i'll try bigger sinks (right now i have fischer's VPR32/38,1)
i would not argue about 15mV DC before the cap but recently i measured 35mV DC after the cap. so the real offset was in the hundreds of mV!!
the output fets are irf530/9530 maybe i should change that too???!!!
kind regards,
attila i
there can't be offset after the cap , except in case of bad one
however , if you don't have any bleeder resistor there (output side of cap) , due to huge DMM impedance , you'll have false DC reading
so - when measuring positions like that , put 100K resistor parallel to probes
however - why at all measuring side of cap , flapping in da breeze ?
:clown:
just chill , and enjoy in muzak
what the heck is "flapping in da breeze" ????
sounds like an idiom for diarrhoea.
sorry i'am not a native english speaker.
there are 100R in series before the cap with 330R to ground as is in the official
circuit.
i came to measure the output offset while measuring the output noise.
besides-> muzak is licensefree audio rubbish as is heard in elevators eg.
cheers
attila i
What ZenMod means is that there needs to be a resistor after the capacitor, 100K or so, in order to read the actual DC offset after the cap.
Do you have 25-turn potentiometers in your bias circuit? That helps.
Also, when these circuits get very, very touchy to adjust, I would suspect a cold solder joint somewhere.
Soooo....
reflow done, there were indeed a few suspect solderpoints
adjustment done, a bit easier than before.
dc out pre cap circa -15 to +15mVdc
noise below 0.5mVac
again, thanks for your kind assistance.
right now listening to "Seks Bomba" from Boston
recommended!!!
attila i.
for those who care
