B1 with Korg Triode
Very cool! Usually it is not an issue with the parts. I suppose that's a good thing 🙂
This is a really good resource for playing with the bias:
https://www.diyaudio.com/community/threads/b1-with-korg-triode.313612/post-7183945
The lower the bias the less stress on the tube. However, it should last a very long time regardless. Also swapping the Leads on both your speaker terminals changes the phase of the distortion. Another fun experiment.
  • Thank You
Reactions: da9520
I think that in the future I will put the tube in a socket. They are no fun to remove as the leads are far from sturdy. Also, mounting could be improved by isolation if a socket were not attached to the board.
Some of you have placed 10 turn pots on the rear panel of the pre. That seems to be a very good idea for those of us who always want to know 'the difference'.
Finished mine just before NY, not my best work, but i expected worse 😀
Bias is set to ~9.5v
Bit dodgy filter board setup, its held by a hot glue. Signal Caps were too big to fit on original PCB, so they had to go flying above in "3D" arrangement 🙂
Mod's replacement as recommended by @Brijac , main resistors, main caps, and signal caps.
Only issue i have is bit with ground when touching pot/chasis, so il have to ground pot and filter pcb, at some later point 🙂
Similar "3D" arrangement here with my build which I finished some months ago. It sounds good! Have fun!! 😀
Gaetano.
Reactions: El Wizardo
Hello Plott,
why shouldn't the B1-NUTUBE fit the M2X?
Only problem could become time - i needed a lot of time to listen through my most preferred input-buffers of the M2X and
the adjustability of the B1_NUTUBE. And try to swap polarity of your loudspeakercables depending on the adjustment of the B1-NUTUBE.
I think you have a long lasting listening programme for the near future... Have fun! 😉
Cheers
Dirk 🙂
Reactions: Plott
