B1 with Korg Triode
A few years back I bought a whole sortiment of WIMA polyester caps (MKS4 and MKS2) to refurbish a Revox tape deck and a Revox reel-to-reel machine. No real complaints using them there (but haven't compared to all MKP caps in this application - probably would be hard to fit size-wise).
But when I tried the MKS in my diy amps, I was never satisfied with them. Too harsh, edgy, unmusical ... 🙄
My default go-to poly caps now are WIMA MKP. If I can fit them, MKP10; otherwise, MKP4 or MKP2.
Small value caps; FKP2.
I'm not even using the MKS in power supplies anymore (I like WIMA DC-Link there, or motor-run MKP).
Of course, ZenMod's Philips MKC are nice as well, or the vintage ERO MKPs ...
Best regards, Claas
Try some KP instead off MKP. Very big difference.
Borg k1 review
This may be a bit long but hopefully helpful. Context-I think I have written less than 5 comments in any venue (Amazon, etc) ever so fact I’m doing this at all should lend significance to these observations. More context - I have been in hobby for about 34 years and have owned lots of top notch equipment : lamm, audio research, krell, counterpoint, transcendent, Martin Logan, acoustat, audiostatic, Proac ( lol, autocorrect wanted to change this to Prozac), Meitner, kef, harbeth, you name it. I currently own and use ram labs rm9ii, Bryson 4bst, pass diy f6, ba3 pre, aleph3 diy (original version). I did own f3 and aleph j, so have familiarity there. Now the punchline. The borg pre is world class performance. I thought ba3 pre was good, but this thing sounds better than anything I have owned previously. It has transformed my system into something so holographic and organic as to sound real on great recordings and makes poor recordings very listenable, even good. This is pairing it with f6 which is magical. Repeat magical. It sounded impressive with aleph 3, and other amps but truly transformed when paired with f6. For the first time ever I don’t have an itch to change anything. Every diyer should do themselves favor and build it. I used everything stock from white paper bom but used twisted pear power supply (positive leg only) and Anker 22v trans. Also used dueland wire. I believe wire makes a difference and I can hear it - whether it is due to metallurgy, dielectric, layout, L/C/R relationship, dunno and no one else does but it makes a difference. This does not mean I condone the wire industry in fact when $8k 8ft wire first started coming on scene years ago , I was so disgusted I left the hobby for awhile. That’s not to say $8k wire can’t sound outstanding, but there is absolutely no value there, even if I were a multi millionaire. Rest of system is rega mid level tt, chord dac with computer server, mogami ic’s (great reasonable wire) and synergistic speaker wire (kimber 8tc works well too and sound very good). Speakers are Solstice by Jeff bagby from parts express. Do yourself a favor there too. Build these. They are incredible and sound better than anything I have heard or owned less than $10k. No exaggeration. They are full range, incredibly dynamic, perfect top end, airy and open, transparent, detailed, and holographic imaging. Solidity and roundness to images in space. Midrange to die for. Again, have absolutely no desire to change unless I came into large sum of money and would then get Wilson Sasha. My borg I have set to about 10.5v. Had it at 9.5 but it sounded a bit dark and muddled, then read white paper again and saw Nelson’s comment that it is not necessarily the ideal point. If 11.5v is approximate null, and each .1v increment translates to about .1% distortion, I figured 10.5 would get me to the target of 1% at 1v. I was going to check everything with ARTA to make sure everything is balanced and right, but it has sounded so damn good that I don’t feel a need. I think a good linear supply is better. Did not try the wallwart/brick method, but it can only be more edgy in my mind, and for those who thought it sounded better this way, i think you can accomplish same thing by adjusting pots if you need a bit more “sharpness” to sound. Anyway, hope this is helpful. Thank you Nelson for sharing your genius. Whenever I now go to listen to my system, I am spellbound (and probably have a stupid grin too). Best sound I have ever had at home.
I agree. I also have a B1 Korg (Papa's Xmas Special) with a DIY F6 and have not heard anything better. Have tried it with my M2X and various input modules and there is no comparison. B1K/F6 is the winning combo. Running 9.7 V on the NuTube plates. Listened at around 10.2 V for a while but went back to more H2. Running a fairly high bias of 1.25 A on the F6, which makes a difference. Needed to change the zeners to 5.6 V to get there. Output devices are at around 65 deg C.
Send us pictures! Please🙂 I am almost done with my B1 Korg Nutube assembly. Was thinking to replace stock wires with silver wires. I used everyhthing else was in the Pioneer's kit. Which capacitors and wire did you use? FYI This is my first DIY experience: amazing what people can do to have Maestro's creations...
I am sure "full charge" is probably over 24V. There is probably no way to tell the charger to stop charging at 24V. I bet your batteries will measure 26V-ish when fully charged.
Distortion profile will not be be better or worse but it will be different from what Mr. Pass designed if the rails are not 24V. The distortion profile changes with changes in rail voltage and unless you have someway of measuring the distortion you will not be able to get the specified harmonics at rail voltages other than 24V.
Also, max voltage for jets is 25V.
Never seen an answer I understood in the battery V's power supply question when posed by relative newcomers such as my self. Certainly you could by or build lithium ion batteries capable of supplying more than enough current for the same price as many mains filters and power supplies and it would be free from any of that.
Would you need any regulation of power coming from a battery or pair of?
Two lead acid batteries in series is 24v. Regulation not required. Would probably work very very well. Be exceedingly careful with batteries as a short can make for hundreds of amps flowing instantly. Aside that obvious warning, give it a try!
