B1 preamp build thread
now the CMF55 seem to be rated at 1/2 watt - although i also saw a spec sheet rating them at 1/4 watt. i guess it's never a problem if a resistor can dissipate more W, right?
me learning a lot about resistors these days 🙂
on a different note i found a nice cap for C1. i was looking for a very small can with as much uF as possible as I'm trying to fit this in a rather small enclosure. i think for the size (25mm dia, 30mm height) this one with 12ooo uF is a good fit: Cornell Dubilier 381LX
The CMF series are non-magnetic. I use them in most of my builds. The rated power dissapation of resistor will vary depending on the ambient temperature. The data sheet tells the whole story. Depending on the resistance, it is sometimes cheaper to buy the CMF series.
I am using this simple circuit to measure them...
I have a question regarding the power on LED. The article says "D2 is a generic LED". I have a few LEDs with a rated forward voltage of 2.1V and forward current of 20 (30max) lying around. Would that work? .... or what else is considered a "generic" LED?
that is pretty much "generic LED"
say that rail voltage is 15V
for calculus , taking 2V for LED is precise enough
sat that we want 5mA through LED (prett bright in most cases)
so R=(Urail-Uled)/Iled
R= 13V/5mA = 2600R ........ first standard is 2K7
dissipation through resistor is P=I^2 x R = 5mA^2 x 2K7 =67.5mW , so regular small resistor is strong enough
