B1 builders thread
Hi rgheck!
you'll be disappointed cause i'm not a real DIYer (sic). I didn't want to get in trouble building a power supply and i got this kit from Cebek at local store, Spanish manufacturer similar to Velleman. It's variable from 12 to 24 Vdc 500mA, i adjusted to 18V and voila!
Cost = 24€ = 30$ = headaches because designing a PS = 0
fuente var. 12 a 24v 500ma - Diotronic
I'm sure you can get similar PS at Radio Shack, Digikey, Mouser or your nearest electronic stuff store.
Hope it helps!
Here are pics of the B1 me and my friend Leslie(brainf) built. PSU is an old Dell PSU.
I have finished a B1 that is powered by an old HP deskjet printer supply. I must say that it was fun to build. This nice little piece sounds astonishing well. For a low enclosure profile I have dislocated the caps off the board.
Im just finishing up a point to point B1.
I wanted to ask about the 1M resistor from input to ground. Since im not using a board is there a preferred place to put it? I can put them on the rca inputs or i thought i could put them on the volume pot between its input and ground.
Should be the same but any thoughts?
thanks
B1 current draw
I built a B1 using the Pass board.
It is silent and works exactly as it should with one problem.
To test it I used 2 9volt batteries in series to supply the 18v.
It works fine but seems to draw an awful lot of current.
Within 5 minutes the batteries are getting warm and are about used up after 20 minutes or so.
Any ideas?
Thanks.
thought i would share a couple of pis of my build.
I decided to go point to point and integrate am mp3 player into the unit... not quite finished, i have to finish mounting the mp3 player and add the faceplate to it and the feet and knob are temporary for the pics also considering adding some leds to give it a glow but not sure yet..
the B1 & F5 have a gain of +15.5dB.
The signal level at the B1 input needs to be higher than usual. 3.5Vpk for maximum output. A CDP is normally capable of ~3Vpk at maximum.
The 27W into 8r0 becomes ~36W into 6r0.
This will give a maximum of ~100dB SPL at 2.5m from a pair of 89dB speakers.
In a 42 sqm room, I would not consider that sufficient.
